Arch Linux Image for MNT Reform
I’m generating an Arch Linux image for the MNT Pocket Reform.
I patched the kernel for all the MNT Reform SoMs, so in theory this should work, or at least boot, on all of them. I only have the i.MX8M Plus Pocket to test on (for now).
I’ve been running Arch on both an SD Card (for testing) and on my NVMe drive for several months now and it runs well with Sway.
The next step here is to get the reform tools installed in full, but at least for now, I added the LPC (reform2_lpc) and qcacld (wlan) kernel modules so WiFi and the display work well.
Comments, questions, issues, and PRs all welcomed. :slight_smile:
Nice! If you have any specific questions that you think i can answer as the author of these scripts for debian or as the author of reform-tools, please do not hesitate to @-mention or ping me directly! (or email of course also always works)
Hey @stephano I can’t seem to generate dkms modules for this kernel
@TwoWheeledIdiot what errors are you seeing? If memory serves you can find the errors in /var/lib/dkms/<module>/<ver>/build/make.log.
Please paste the errors and the following info:
uname -r
readlink -f /lib/modules/$(uname -r)/build
ls -1 /lib/modules/$(uname -r)/
A few common culprits:
  1. Ensure you’ve installed the right kernel headers and they are installed at /lib/modules/$(uname -r)/build (you can get those from the release artifacts, or if running Arch, from GitHub - cetola/linux-mnt-pocket-headers: Kernel headers for building modules on the MNT Pocket Reform running Arch)
  2. Ensure there is not a kernel release string mismatch (should be “-mnt-pocket”)
  3. Not sure which distro you’re using. Technically you could use this kernel with any aarch64 compiled filesystem you can get working. :slight_smile: Be sure your distro doesn’t expect certs/signing_key.pem or scripts/sign-file to exist under /lib/modules/.../build.
So I figured out one part of the problem, ulimit was set to 1024. I increased the file limit to fix it. A new problem has reared its ugly head dkms now starts but it segfaults after 8 seconds. As a note I am using void, your kernel is the only one that I can get to boot on my pocket (edit: grammer and structure)
Oh I see the issue. I need to update the gen-headers script as it is shipping sources, generated headers, Module.symvers, AND host-built executables. So you have a bunch of x86_64 executables that the DKMS build is trying to call.
I’ll have to think about the best way to fix this. I’m relatively new to cross compiling kernel headers.
That would explain the segfaults, For now Ill just compile the kernel on device. you could try installing an arm arch install to a directory on your x86 machine then with the binfmt service installed and enabled you should be able to compile the kernel without any non-arm code ending up in the kernel
Good idea, and thanks for the feedback / trying out the kernel. I’ll probably use binfmt as a backup path. I use it to run dracut when generating the Arch image and it works great for that.
I’ve been debating a native Arm EC2 Spot Instance rather than the x86 one I’m using now. I think that would be best long term.
Issue created:
@TwoWheeledIdiot I finally had a chance to dig into building kernel headers. It turns out there’s a script in the kernel tree scripts/package/install-extmod-build. It is an upstream kbuild helper that assembles the minimal kernel build tree required for compiling out-of-tree modules (e.g., via DKMS), including generated headers, Module.symvers, and necessary build scripts. It is used by the kernel’s deb-pkg and rpm-pkg targets to create the linux-headers/kernel-devel package contents. It also knows about CROSS_COMPILE unlike my previous hacky attempt.
I’m going to use it to test a clean, upstream-aligned way of producing a DKMS-compatible headers tree without manually copying and pruning the full build directory. Even though it introduces a dependency on upstream packaging internals, it provides a well-defined and actively maintained baseline for validating that external module builds work correctly.
Arch in particular does not do this, but rather ships the whole build tree minus some pruning. Since the point here is for me to learn, I should probably do that. However I’d rather focus on other tasks for now, like porting reform-tools over to a PKGBUILD for Arch (see @josch I remembered :slight_smile: ).
I’m testing a fresh build of 6.18.9 out and will report back if it fixes the DKMS issue you were seeing. Of note, I’ve upgraded to the A311D chip, so I’m also testing the kernel & header builds on a new SoM. Why change one thing when you can change 4? :thinking:
DKMS is fixed. Or at least fixed well enough that my “hello world” module builds across multiple kernel upgrades. :grin:
I’ve also started work on porting the reform-tools (hi @josch). The images will not contain these tools by default while they are still in “beta” form, but you can install manually or via the PKGBUILD. You can also find them on the AUR repo.
I’ve started tarring / installing the kernel, wlan, and lpc modules separately now. I’ve created a table in the README.md for all the available PKGBUILDs.
I’ll move the PKGBUILDs to AUR as they mature, but since reform-tools was already there and out of date I figured an update was worth it.
Wonderful! Send me your bugs and feature requests related to Arch.
Tools like reform-check are currently apt/dpkg-only but they should be distro agnostic. If you send me a patch to make reform-check work for Arch, Ill merge it. There is for example a WIP MR for Void Linux here: Draft: Update reform-check to work with Void linux (!115) · Merge requests · Reform / MNT Reform Tools · GitLab
I’ll give some thought to a more distro agnostic approach. I started to look at scripts like reform-check. Ideally we’d avoid giant case statements, but I haven’t had enough time and coffee to think about a good way around this. :slight_smile:
See the MR for more ideas on how to architect this.
After reading the MR I really like the idea of templating. I haven’t used jinja in a little over a decade so I’ll have to dust off that knowledge a bit. :wink:
