You can quickly remap keys using this interface, then download the .elf file to flash using dfu-programmer. You’ll need to be sure the switch at SW84 is set to the on position, and click the button at SW83 to enter flashing mode. This is the best way to do it since the changes will stick no matter where you use the keyboard. Hope this helps!
Thank you! I wasn’t aware of the page (or forgot about it), but that’s wonderful!
I somehow hoped, that it were possible to just reconfigure keys with a simple shell command, but flashing the firmware might be the better solution anyway. I don’t need any special hardware for flashing, right? sudo apt install dfu-programmer is all I need?
That’s correct, no special hardware required…all you need is to install dfu-programmer. The keyboard appears as a flashable device to dfu-programmer once you’ve hit the little button. Try it and let us know how it goes!
Worked like a charm. Thanks again. Now I only need three blank key caps (1U, 1U, and 1.5U) to replace the wrong keys. Or, alternatively, two 1U which say “COMPOSE” and one 1.5U which says “ALT”
Hello, I was trying to do the same thing but cannot get it to work …
When I type the command dfu-programmer atmega32u4 erase --suppress-bootloader-mem I get an usage prompt, suggesting this command is not valid. I checked the documentation and it seems that --suppress-bootloader-mem isn’t a valid option fot the erase command …
So I tried the command without options, and got dfu-programmer: no device present in return.
I don’t really know where to go from there, so if anyone was able to solve a similar issue, I would gladly accept any advice !
Hello, sorry if I didn’t respond for a while, I moved and didn’t use the keyboard for a while so I kinda forgot about this …
I had some time to set it up again recently, and after updating everything, and trying again, I could successfully flash the software !? I don’t really know what changed but at least it’s working now !
Thanks for your help anyways !
