Correct. But this is great because this means that the reform-check utility gets a lot of testing from you. Thanks to your feedback I now uploaded a new version of reform-check
with these additional features:
- if
/etc/apt/preferences.d/reform.pref
doesn’t exist, explain what its contents should be - if
doesn’t exist, explain that it’s dangerous to install any packages - check if
/etc/fstab
has an entry for/
and if not, suggest a correct entry based on what is currently mounted as/
- check if
/etc/fstab
has an entry for/boot
and if not, suggest a correct entry depending on whether/boot
is on sd-card or eMMC - check if anything is mounted on
/boot
and if not, suggest to fix/etc/fstab
- if
/boot/flash.bin
doesn’t exist, suggest how to obtain the most recent version - if
/etc/flash-kernel/machine
suggest that it should either containMNT Reform 2
orMNT Reform 2 HDMI
which can be achieved by runningreform-display-config
- if
/etc/default/flash-kernel
doesn’t exist, suggest what to put into it - if
/etc/initramfs-tools/modules
doesn’t exist, suggest what to put into it - check if the
https://mntre.com/reform-debian-repo
repository is enabled and if not, suggest what to put into/etc/apt/sources.list
to do so - check if the
linux-image-arm64
can be obtained by the mntre.com repo or not - check if the installed
linux-image-arm64
package comes from the mntre.com repo or not - if
/boot/boot.scr
doesn’t exist, suggest runningupdate-initramfs -u
to create it - if
/etc/modprobe.d/reform.conf
doesn’t exist, suggest which lines to put into it
Essentially, your problem seems to be that you are using a system before sysimage-v3 and u-boot is finding a kernel on a /boot partition somewhere and that kernel successfully boots your system on nvme but then your system doesn’t mount /boot and thus your kernel is never updated. In a way that is good, because if it were updated, you would not use the patched kernel from mntre.com and the missing initramfs-modules, flash-kernel entries and missing modprobe blacklisting would make your system unbootable anyways.
I suggest you take a snapshot of your system and then attempt to upgrade it to sysimage-v3. I don’t know how much i’ll manage to be online on IRC during the holidays but maybe we catch each other some time soon.
