Hello, I have a few questions about the Pocket Reform.
The website says it has a 7-inch display. Is it comparable to my Steam Deck LCD in terms of size and UI elements? Don’t both have a 16:10 aspect ratio?
How can I reinstall the OS on the device? Is it similar to what I’m used to with Linux, or are there extra steps when using the image from MNT?
I would like to buy it in Ultra Purple, but in many review photos the color looks lighter and reflects light, which doesn’t seem to be the case in the pictures on the MNT shop.
I don’t own a steam deck, so I cannot comment on that part of your question and will leave it to others, but:
If you go with the official MNT Debian distro, then you can flash it to an SD-card, put this into your Pocket Reform and it will automatically bot the system from that SD-card. Once you are in the system, you can use the script reform-setup-encrypted-disk to re-format your SSD and fill it with a copy of the system you are running from SD-card but with full disk encryption. You can then shut down the unit, remove the SD-card and the next time you boot the system it will boot from SSD and show you the password prompt for the disk encryption.
It’s hard to get a good impression of colors because lighting is always different, the sensors of our digital cameras do different things than our eyes and our screens are unable to show the colors our eyes can see.
Here are a bunch of photos I took in different light conditions:
Hi @josch
Thank you for answering my questions!
The pictures of your deice look really cool. The color is a nice change from the usual black, gray, or silver.
I’m thinking about buying the Pocket Reform with the QCS6490. Would you say it runs faster than my test PC, which has an Intel i5-6500?
If I use LibreOffice to write something at university while also having a browser window open, would the processor get too hot?
I also read in the MNT News that there might be a Pocket Reform with a touchscreen in the future. Do you think I should wait for it? Having a touchscreen would be quite useful.
The screen is about the same size as a steamdeck but at a higher resolution 1920x1200 vs 1280x800. I set resolution scale to 166% in gnome and its comparable to steamdeck UI size, maybe a little more compact.
The QCS6490 does seem to edge out the i5-6500 in benchmarks but not by much.
@hardcoreufo@minute@josch
Thanks to everyone who answered my questions!
I’ve had my eye on the Pocket for the past 2.5 years, and I’ve finally decided to buy one at the end of this semester.
It will be my first open-source PC in my small collection.
i’ve been hesitating with buying it for years too. now it giving me hard times, but still my issues can be solved i believe. anyway, it is the first time in my life ever i LOVED a device. no regrets buying this little cutie whatsoever.
