With one problematic charger here I found reversing the usb-c plug helps. Could try that.
I have a rudimentary usb-pd debugger - it doesn’t show all traffic or requests, but it does show some unusual behavior from the pocket.
| Header | Message Type | Message Body | Source | Decoded |
| 0x4161 | Source_Cap | 0801912C 0002D12C 0004B0C8 00064096 |
charger | 0801912C - Unconstrained, 3 amps, 5 volts 0002D12C - 3 amps, 9 volts 0004B0C8 - 2.2 amps, 15 volts 00064096 - 1.5 amps, 20 volts |
| 0x4161 | Source_Cap | charger | ||
| 0x1242 | Request | 41000401 | 4th object, no usb suspend, 10 ma, max 10 ma | |
| 0x0363 | Accept | charger | ||
| 0x0566 | Ready | charger |
This test was with the pocket som (rcm4-a311d) powered off - when the pocket som is powered on, I get no data on my debugger (more likely a limitation of my debugger). Charger is a “anker powerport speed 30”
- The number of source capabilities messages is odd - sometimes i’d see 20+ messages from the charger before the pocket would respond with a request. (I have a capture from an ipad, and it only needed one source capability message from the same charger before requesting)
- The pocket is setting the max amperage and requested amperage to only 10 ma - I don’t know how chargers are expected to respond to this behavior - but this is out of spec (the pocket then goes on to draw more than 10 ma)
I would occasionally get into the loop of charge/not charge with an OEM 200W charger Random shutdown and the development version of sysctl firmware that has PD improvements resolves the problem with this charger. Note that while the charger has technically a number of ports and high output power only two of the USB C ports can be used reliably. When 3 ports are used the charger firmware starts to struggle with allocating power between the ports, and a reconfiguration loop can happen on the charger side.
Sorry if that seems like offtopic (I can create a new thread if it is)
but what are the limits of fast charging lifepo4 batteries in the reform devices (assuming that all three models are the same in that regard), and what are also the theoretical limits?
do they come from hardware, from the batter chemistry or both?
does using PD 3.1 make any difference? and same question for PPS?
I don’t know the answer to your question (sorry) but just wanted to clarify that the pocket has lithium ion pouches instead of lifepo4
