Hello.
The power supply that comes with MNT Reform is 110 / 220V. However, the voltage used in my country (Japan) is 100V (95V-105V). I don’t have the knowledge to determine if the difference is a problem.
I think it might be better to buy a 24V 2A power supply that supports 100V. Does anyone know if I can use a 110V power supply?
I’m not good at English, so I’m sorry if there is something you don’t understand.
Thank you.
