WiFi AsiaRF M27612-BU3 + Rockchip RK3588?
I understand that the Rockchip RK3588 module does not provide WiFi. So I odered the Wi-Fi Card with the AsiaRF M27612-BU3. However, that card is only supposed to work with the i.MX8M Plus or A311D - not the Rockchip RK3588. So now I am confused - will the AsiaRF card work with the Rockchip RK3588? Can I install the AsiaRF card and an SSD?
  1. AsiaRF will work on rk3588 as long as there are driver
  2. There are two M.2 slot(B and M) on pocket reform mainboard AsiaRF card is M.2 B key and SSD is M.2 M key.
Great, thanks for clarifying!
It might be a good idea to change the product page of the WiFi set accordingly and add it to the configuration options of the Reform then. :slightly_smiling_face:
