Workaround for depleted battery cells not charging (Pocket Reform not powering on)
Yesterday we had a warranty inspection @ MNT of a Pocket Reform that wouldn’t turn on and wouldn’t react to a USB-C power supply being plugged in. One of the battery cells measured 2.7V (with Multimeter across charger module connector).
I discovered a workaround: disconnect the power supply. On the mainboard, set the programming switch (PROG) to on. Press the nearby RESET button of the System Controller. Reconnect the power supply. If you have an inline PD power monitor you’ll see that Pocket Reform now draws some power. The charger module is charging autonomously, while the System Controller isn’t active at all in this state. Let it charge for a few minutes. Disconnect the cable. Turn the programming switch off again. Press the reset button. Reconnect the USB-C PD cable. The system should now charge normally.
The cause of this is probably the undervoltage limit programmed by the firmware into the charger module’s monitor chip, which then breaks the current flow. This needs to be investigated in the System Controller firmware. An idea would be to hold off programming this limit until wall power is lost for the first time. This would then still prevent overdischarge, but allow it to charge to a safe state when cold-started by a USB-C power supply.
This would be incredibly useful.
Because I’m using mine every few days, and not every day, I quite often come to it to find that the cells have discharged below the undervoltage limit. I now keep two Lipo chargers on my desk and a spare jumper in the bag for the bypass.
At the moment, this is the one bit that’s causing me more problems than anything else. Coming to the Pocket and finding the batteries unexpectedly discharged below the safe discharge level, and having to mitigate that before I can continue with whatever I was planning on doing.
The firmware being able to do this would be a genuine game-changer and a relief.
This might be my problem I’m having in Pocket Reform doesn't start, doesn't light up, doesn't charge - Any tips? . Will have to test this.
(Edit: Probably not. I got it working again. So might have been tired brain + broken switch problem.)
