- Amiga model: A4000D RevB
- 680x0 CPU:060 rev 6
- RAM Configuration: 2mb chip, 16mb fast + zz9000ram
- Kickstart, AmigaOS Versions:3.2
- ZZ9000 Firmware version:1.9
- ZZ9000 Driver version:1.8
- Monitor model:Ilyama
- Other Zorro cards:buddha
Hi, does the mac address for the ZZ9000 change at all? Just that I reserved an internal IP address to the mack address printed on the quick start manual a few days ago, and that was working fine.
Just turned the miggy on now, and the mac address seems to have changed? Is there a way of forcing it to stay the same?
Utukku
