Hello,
I have got the following error when trying to upgrade today:
shigeru@mntpr-0:~$ sudo apt full-upgrade
linux-headers-6.14.5-common reform-qcacld2-6.14.6-mnt-reform-arm64
linux-kbuild-6.14.5
Upgrading:
flash-kernel reform-qcacld2
linux-image-6.15.3-mnt-reform-arm64 reform-qcacld2-6.15.3-mnt-reform-arm64
REMOVING:
linux-headers-6.14.5-mnt-reform-arm64 linux-image-6.14.5-mnt-reform-arm64
Summary:
Upgrading: 4, Installing: 0, Removing: 2, Not Upgrading: 0
Download size: 78.5 MB
Freed space: 170 MB
Continue? [Y/n]
Get:1 https://mntre.com/reform-debian-repo reform/main arm64 linux-image-6.15.3-mnt-reform-arm64 arm64 6.15.3-1~exp1+reform20250622T211021Z [76.8 MB]
Get:2 https://mntre.com/reform-debian-repo reform/main arm64 flash-kernel arm64 3.109+reform20250520T044859Z+1 [33.2 kB]
Get:3 https://mntre.com/reform-debian-repo reform/main arm64 reform-qcacld2-6.15.3-mnt-reform-arm64 arm64 20250624T094928Z [1,218 kB]
Get:4 https://mntre.com/reform-debian-repo reform/main arm64 reform-qcacld2 arm64 20250624T094928Z [414 kB]
Fetched 78.5 MB in 21s (3,672 kB/s)
Preconfiguring packages ...
(Reading database ... 494094 files and directories currently installed.)
Removing linux-headers-6.14.5-mnt-reform-arm64 (6.14.5-1~exp1+reform20250508T045900Z) ...
Removing linux-image-6.14.5-mnt-reform-arm64 (6.14.5-1~exp1+reform20250508T045900Z) ...
Usage: /usr/bin/linux-run-hooks image MAINT-SCRIPT KERNEL-VER IMAGE-PATH -- MAINT-PARAMS ...
/usr/bin/linux-run-hooks headers MAINT-SCRIPT KERNEL-VER -- MAINT-PARAMS ...
This command is intended to be called from the maintainer scripts of
Linux kernel image and headers packages. It executes hooks installed
in the appropriate subdirectories of /etc/kernel and
/usr/share/kernel.
The MAINT-SCRIPT argument must be the name of the maintainer script:
preinst, postinst, prerm, or postrm.
The KERNEL-VER argument must be the kernel version string as shown by
'uname -r' and used in filenames, not the package version.
The IMAGE-PATH argument must be the absolute filename of the kernel
image.
The MAINT-PARAMS arguments must be the parameters received by the
maintainer script.
dpkg: error processing package linux-image-6.14.5-mnt-reform-arm64 (--remove):
installed linux-image-6.14.5-mnt-reform-arm64 package pre-removal script subprocess returned error exit status 2
dpkg: too many errors, stopping
Processing was halted because there were too many errors.
Here is sudo reform-check output:
shigeru@mntpr-0:~$ sudo reform-check
I: `uname -a` output: Linux mntpr-0 6.15.3-mnt-reform-arm64 #1 SMP Debian 6.15.3-1~exp1+reform20250622T211021Z (2025-06-22) aarch64 GNU/Linux
I: Version of linux-image-mnt-reform-arm64: 6.15.3-1~exp1+reform20250622T211021Z
I: Version of reform-tools: 1.74-1+reform20250622T103710Z+1
E: Your /etc/skel/.profile contains an outdated line that attempts to print /etc/reform-help or run reform-help.
E: Consider simply deleting that offending last line of your /etc/skel/.profile.
Should I do autoremove and upgrade separately?
Thanks.
