A2000 Boot Problem with 68000
Hello
Normally I use my Blizzard 2060 and everything is fine. But booting the A2000 with the 68000 only it hangs. It’s not even possible to reach the early boot menu. I have to remove the ZZ9000.
It makes no difference if I just switch of the Blizzard via the 0-Key or if I remove the Blizzard.
  • Amiga model: A2000 Rev6.2
  • 68000 CPU: 68060 and 68000
  • RAM Configuration: 1MB Chip, no 24Bit, 96MB on Blizzard, 4MB ZZ9000
  • Kickstart, AmigaOS Versions: 3.2.3
  • ZZ9000 Driver version: 1.13
  • Monitor model: old NoName TV via HDMI
  • Other Zorro cards: AriadneII
