- Amiga model: AA3000+
- 680x0 CPU: 68060
- RAM Configuration: 128MB (BFG9060)
- Kickstart, AmigaOS Versions: 3.2.2
- ZZ9000 Firmware version: 1.13
- ZZ9000 Driver version: ?
- Monitor model:
- Other Zorro cards: A4091
With the riser-card for AA3000+, video slot is bottom-most. So typically i’d put zz9000 in bottom-most slot due to the short ribbon cable to connect between video-slot and zz9000.
With this configuration, installing an A4091 afterwards allows for the scsi card to be detected, but not any drives on a zuluscsi.
If i reverse the order of cards, then the A4091 can see the drives on zuluscsi, and zz9000 seems to be operational as well - but now i can’t get video passthrough support due to card ordering / configuration.
is there any way to possibly remedy this issue, even possibly losing my z3 RAM on the zz9000? (I don’t see a z3-noram firmware anymore though)
