I’d like to modify my keyboard firmware so that the backlight dims to a low level after a few minutes of not using it. I’m a beginner at this stuff so curious if others have any input.
It appears to me that keyboard.c contains the function I’ll want to modify: int main (void){}
and already contains some variables pertaining to whether any keys are pressed and when, like total_pressed
, last_meta
, and counter
backlight.c contains the functions called when changing the backlight state, so it seems all I need to do is add some kbd_brightness calls to keyboard.c?
If I successfully implement this I’ll post my results.
