Following on from a brief comment here…
I have a Quectel EM060K-EA on the way to go in the WWAN slot, but in the meantime I have been trying out some other things.
- an SD Card adapter
“M.2 Micro SD Card Reader Micro Micro SD SDHC SDXC TF to M2 B Key T-Flash Adapter for Desktop Laptop M.2 NGFF SSD Support 512GB”
It’s a B-keyed card with a micro SD card slot. When plugged in, a red light comes on indicating that it is getting power from the slot; when an SD card is inserted, a green light comes on indicating that it is seen by the adapter at least. Marked as TFNGFFVA2 with a SAGE chip marked S682A16 202244.
Nothing shows up in dmesg or lsusb or lspci or lsblk on the Pocket Reform even though it is all lit enthusiastically.
- a USB adapter
“Laptop M.2 B Key to Wireless Bluetooth-Compatible WiFi Network Card USB 3.0 SSD NGFF 3042 Converter M2 Key-B WWAN 4G Slot to USB3.0 Adapter”
marked as WK5 V1.1 ADT LINK
There are no LEDs with this one. It has a single USB A socket on the inside of an open square cut out in the board. I’ve tried loading a tiny Netgear / Realtek wifi card into that.
On insertion I’ve seen messages like this in dmesg output
[ 189.421594] usb 1-1.4: new high-speed USB device number 5 using xhci-hcd
[ 189.522789] usb 1-1.4: New USB device found, idVendor=0846, idProduct=9041, bcdDevice= 2.00
[ 189.522813] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 189.522822] usb 1-1.4: Product: 802.11n WLAN Adapter
[ 189.522830] usb 1-1.4: Manufacturer: Realtek
[ 189.522837] usb 1-1.4: SerialNumber: 00e04c000001
[ 189.614610] usb 1-1.4: can't set config #1, error -71
[ 189.710718] usb 1-1.4: USB disconnect, device number 5
[ 192.666020] usb 1-1-port4: Cannot enable. Maybe the USB cable is bad?
[ 195.434295] usb 1-1-port4: Cannot enable. Maybe the USB cable is bad?
[ 195.434458] usb 1-1-port4: attempt power cycle
[ 216.915815] hub_port_connect: 12 callbacks suppressed
[ 216.915833] usb 1-1-port4: connect-debounce failed
Nothing in lsusb or lspci and it seems to not fully connect. Some searching seems to indicate that this is a protocol error and could be due to power or something else. The USB wifi adapter ends up getting very hot (I know because I took it out afterwards and the metal USB A connector was uncomfortably warm), so I didn’t want to leave it in.
Just wanted to share my experiences with alternative uses of the WWAN slot since these were mentioned elsewhere. Anyone else found devices that work there?
