With the news that my post-crowdfunding Reform will soon be on its way (yay!), I thought it would be a good time to ask a question that has been bugging me for a bit.
The operator handbook reads:
You may be tempted to try cells of other chemistries like Li-Ion or NiMH, but never do this, as these are incompatible.
Only use LiFePO4 cells with MNT Reform!
Why is this so? Could the Reform’s design be modified to incorporate battery cells with higher energy density?
I tried searching (and asking) around to understand why a charging circuit would be incompatible with certain chemistries, but didn’t find an answer. I’m a novice to electronics, so I’d be happy to be pointed to a general reference to understand the principles behind this warning.
so please
You definitely raised some interesting points about Li-Ion cells that I didn’t know about. For me personally, the benefit of >2x energy capacity (for the specific cells I’m comparing) compared with LiFePo4 is hard to ignore for a portable computer. Do you know if there any chemistries that strike a good middle ground between really low density and being a hellish safety hazard? Or alternative ideas to increase usability of a portable computer making use of LiFePo4 cells?
) on AliExpress and have had good luck with it so far. It does about ~22W fast charging with USB-C PD so based on another post I saw here recently it should perform quite well charging the Reform. It already does decently with my tablet PC which sits around 10W for most of my workload, though charging is quite slow unless the PC is off.
