AmigaOS 4.1 and ZZ9000
  • Amiga model: Amiga 4000D
  • 680x0 CPU: 68060
  • RAM Configuration: 128mb + 112mb hack
  • Kickstart, AmigaOS Versions: kick 3.2 - AmigaOS 4.1FE
  • ZZ9000 Driver version:
  • Monitor model:
  • Other Zorro cards: Delfina Lite - Mediator
Hello, i have a very expanded A4000 inside a full Micronick Tower, i’d like to make an AmigaOS 4.1FE installation and use ZZ9000 i/O with that (above all Ethernet and USB) but will use Radeon for GFX but found no drivers for AmigaOS 4.1, isn’t it supported?
Hi, I don’t have access to the hardware to run AmigaOS 4.1 with, unfortunately, so I can’t say if it works or not.
i made some tests by myself, i can tell you that the ethernet device works flawlessly, AmigaOS 4.1FE surfs the net without any problem, i was not able to test the video part because installing the video device is not that easy. USB port seems not to work but actually i was not able to us it even on AmigaOS 3.9.
I Am considering to buy a ZZ9000AX to replace my Delfina Lite sound board but but i’d like to know if someone else uses it with AmigaOS 4.1.
For zz9000 video output there is a guide here for AmigaOS4.1.
