Hey polydactyl! I’m thinking about putting together my PCB. Thanks for handing these out! So neat!!
Just getting confirmation on a few things before committing…
The Atmega-based board is still sold out. Do you think the keyboard design will work with the Adafruit RP2040 itsybitsy along with the upcoming keyboard firmware for 2040…@minute is that available yet? I assume the voltage regulator still needs to be removed/bridged, right? And the 5v rail should be severed (as noted on the back), and replaced with 3v3?
Due to the tight clearance with the hotswap sockets, I might just do through-hole keyswitches for the entire board (I had some white v1s that I test fitted and they seem fine). I need to look into the RGB lights…I will miss full backlighting but if I can get this working at all I’ll feel like I accomplished something! It’s a little ambitious with my skills but I’d hate to let this board sit around.
