Hello everyone!
I’m getting the following error on my Pocket Reform when trying to apt upgrade. Any ideas on how to solve this? Thanks for your time.
guiller@pocket:~$ sudo apt update
Hit:1 http://deb.debian.org/debian unstable InRelease
Ign:2 https://mntre.com/reform-debian-repo reform InRelease
Hit:3 https://mntre.com/reform-debian-repo reform Release
Ign:4 https://mntre.com/reform-debian-repo reform Release.gpg
All packages are up to date.
Notice: Missing Signed-By in the sources.list(5) entry for 'https://mntre.com/reform-debian-repo'
guiller@pocket:~$ sudo apt upgrade
You might want to run 'apt --fix-broken install' to correct these.
Unsatisfied dependencies:
libavif16 : Depends: librav1e0.7 (>= 0.5.1) but it is not installed
Error: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
guiller@pocket:~$ sudo apt -f install
Correcting dependencies... Done
libdrm-nouveau2 libusbmuxd6
libimobiledevice6 libx265-199
libjxl0.7 linux-headers-6.8.9-common
libplist3 linux-headers-6.8.9-mnt-reform-arm64
libpython3.11-minimal linux-image-6.8.9-mnt-reform-arm64
libpython3.11-stdlib linux-kbuild-6.8.9
libpython3.11t64 python3.11
libroc0.3 python3.11-minimal
libspatialindex6 reform-qcacld2-6.8.9-mnt-reform-arm64
libsvtav1enc1d1 reform-qcacld2-6.9.7-mnt-reform-arm64
Installing dependencies:
librav1e0.7
Summary:
Upgrading: 0, Installing: 1, Removing: 0, Not Upgrading: 0
1 not fully installed or removed.
Download size: 0 B / 655 kB
Space needed: 2,193 kB / 110 GB available
Continue? [Y/n] Y
(Reading database ... 261229 files and directories currently installed.)
Preparing to unpack .../librav1e0.7_0.7.1-3+b1_arm64.deb ...
Unpacking librav1e0.7:arm64 (0.7.1-3+b1) ...
dpkg: error processing archive /var/cache/apt/archives/librav1e0.7_0.7.1-3+b1_arm64.deb (--unpack):
trying to overwrite '/usr/lib/aarch64-linux-gnu/librav1e.so.0.7.1', which is also in package librav1e0:arm64 0.7.1-2
guiller@pocket:~$
