Apt upgrade with error warning
Hello,
I am getting Calculating upgrade... Error! when I issue sudo apt upgrade or sudo apt full-upgrade for the past few days.
Also, it postpones reform-desktop-minimal is it an expected result?
$ sudo apt upgrade
Not upgrading:
Summary:
  Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 1
Thanks.
Hi @shigeru I just talked with apt developer Julian Klode and got word that what you see there can happen when the new solver evaluation is running and it fails but it continues with the classic solver result. So this is probably harmless even though I agree that seeing “Error” looks scary.
It should upgrade fine when you use sudo apt full-upgrade. Can you confirm?
Hello!
Here is the result of the sudo apt full-upgrade I just ran. Still reform-desktop-minimal is not upgraded. I do not know why…
Thank you.
$ sudo apt full-upgrade
The following package was automatically installed and is no longer required:
  reform-qcacld2-6.14.5-mnt-reform-arm64
Use 'sudo apt autoremove' to remove it.
Upgrading:
  linux-headers-mnt-reform-arm64  linux-libc-dev
  linux-image-mnt-reform-arm64    reform-qcacld2
Installing dependencies:
  linux-headers-6.14.6-common
  linux-headers-6.14.6-mnt-reform-arm64
  linux-image-6.14.6-mnt-reform-arm64
  linux-kbuild-6.14.6
  reform-qcacld2-6.14.6-mnt-reform-arm64
Suggested packages:
  linux-doc-6.14
Not upgrading:
Summary:
  Upgrading: 4, Installing: 5, Removing: 0, Not Upgrading: 1
  Download size: 93.6 MB
  Space needed: 237 MB / 794 GB available
  └─ in /boot:  80.6 MB / 219 MB available
Continue? [Y/n]
Get:1 https://mntre.com/reform-debian-repo reform/main arm64 linux-image-6.14.6-mnt-reform-arm64 arm64 6.14.6-1~exp1+reform20250508T045900Z [75.7 MB]
Get:2 https://mntre.com/reform-debian-repo reform/main arm64 linux-headers-6.14.6-common all 6.14.6-1~exp1+reform20250508T045900Z [10.9 MB]
Get:3 https://mntre.com/reform-debian-repo reform/main arm64 linux-kbuild-6.14.6 arm64 6.14.6-1~exp1+reform20250508T045900Z [1,324 kB]
Get:4 https://mntre.com/reform-debian-repo reform/main arm64 linux-headers-6.14.6-mnt-reform-arm64 arm64 6.14.6-1~exp1+reform20250508T045900Z [1,536 kB]
Get:5 https://mntre.com/reform-debian-repo reform/main arm64 linux-headers-mnt-reform-arm64 arm64 6.14.6-1~exp1+reform20250508T045900Z [1,176 B]
Get:6 https://mntre.com/reform-debian-repo reform/main arm64 linux-image-mnt-reform-arm64 arm64 6.14.6-1~exp1+reform20250508T045900Z [1,472 B]
Get:7 https://mntre.com/reform-debian-repo reform/main arm64 linux-libc-dev all 6.14.6-1~exp1+reform20250508T045900Z [2,484 kB]
Get:8 https://mntre.com/reform-debian-repo reform/main arm64 reform-qcacld2-6.14.6-mnt-reform-arm64 arm64 20250511T124839Z [1,222 kB]
Get:9 https://mntre.com/reform-debian-repo reform/main arm64 reform-qcacld2 arm64 20250511T124839Z [413 kB]
Fetched 93.6 MB in 18s (5,166 kB/s)
Selecting previously unselected package linux-image-6.14.6-mnt-reform-arm64.
(Reading database ... 355473 files and directories currently installed.)
Preparing to unpack .../0-linux-image-6.14.6-mnt-reform-arm64_6.14.6-1~exp1+reform20250508T045900Z_arm64.deb ...
Unpacking linux-image-6.14.6-mnt-reform-arm64 (6.14.6-1~exp1+reform20250508T045900Z) ...
Selecting previously unselected package linux-headers-6.14.6-common.
Preparing to unpack .../1-linux-headers-6.14.6-common_6.14.6-1~exp1+reform20250508T045900Z_all.deb ...
Unpacking linux-headers-6.14.6-common (6.14.6-1~exp1+reform20250508T045900Z) ...
Selecting previously unselected package linux-kbuild-6.14.6.
Preparing to unpack .../2-linux-kbuild-6.14.6_6.14.6-1~exp1+reform20250508T045900Z_arm64.deb ...
Unpacking linux-kbuild-6.14.6 (6.14.6-1~exp1+reform20250508T045900Z) ...
Selecting previously unselected package linux-headers-6.14.6-mnt-reform-arm64.
Preparing to unpack .../3-linux-headers-6.14.6-mnt-reform-arm64_6.14.6-1~exp1+reform20250508T045900Z_arm64.deb ...
Unpacking linux-headers-6.14.6-mnt-reform-arm64 (6.14.6-1~exp1+reform20250508T045900Z) ...
Preparing to unpack .../4-linux-headers-mnt-reform-arm64_6.14.6-1~exp1+reform20250508T045900Z_arm64.deb ...
Unpacking linux-headers-mnt-reform-arm64 (6.14.6-1~exp1+reform20250508T045900Z) over (6.14.5-1~exp1+reform20250508T045900Z) ...
Preparing to unpack .../5-linux-image-mnt-reform-arm64_6.14.6-1~exp1+reform20250508T045900Z_arm64.deb ...
Unpacking linux-image-mnt-reform-arm64 (6.14.6-1~exp1+reform20250508T045900Z) over (6.14.5-1~exp1+reform20250508T045900Z) ...
Preparing to unpack .../6-linux-libc-dev_6.14.6-1~exp1+reform20250508T045900Z_all.deb ...
Unpacking linux-libc-dev (6.14.6-1~exp1+reform20250508T045900Z) over (6.14.5-1~exp1+reform20250508T045900Z) ...
Selecting previously unselected package reform-qcacld2-6.14.6-mnt-reform-arm64.
Preparing to unpack .../7-reform-qcacld2-6.14.6-mnt-reform-arm64_20250511T124839Z_arm64.deb ...
Unpacking reform-qcacld2-6.14.6-mnt-reform-arm64 (20250511T124839Z) ...
Preparing to unpack .../8-reform-qcacld2_20250511T124839Z_arm64.deb ...
Unpacking reform-qcacld2 (20250511T124839Z) over (20250508T063152Z) ...
Setting up linux-libc-dev (6.14.6-1~exp1+reform20250508T045900Z) ...
Setting up linux-kbuild-6.14.6 (6.14.6-1~exp1+reform20250508T045900Z) ...
Setting up linux-headers-6.14.6-common (6.14.6-1~exp1+reform20250508T045900Z) ...
Setting up linux-image-6.14.6-mnt-reform-arm64 (6.14.6-1~exp1+reform20250508T045900Z) ...
I: /vmlinuz.old is now a symlink to boot/vmlinuz-6.14.5-mnt-reform-arm64
I: /initrd.img.old is now a symlink to boot/initrd.img-6.14.5-mnt-reform-arm64
I: /vmlinuz is now a symlink to boot/vmlinuz-6.14.6-mnt-reform-arm64
I: /initrd.img is now a symlink to boot/initrd.img-6.14.6-mnt-reform-arm64
/etc/kernel/postinst.d/dkms:
Sign command: /lib/modules/6.14.6-mnt-reform-arm64/build/scripts/sign-file
Signing key: /var/lib/dkms/mok.key
Public certificate (MOK): /var/lib/dkms/mok.pub
Autoinstall of module reform2_lpc/1.72 for kernel 6.14.6-mnt-reform-arm64 (aarch64)
Building module(s)...... done.
Signing module /var/lib/dkms/reform2_lpc/1.72/build/reform2_lpc.ko
Installing /lib/modules/6.14.6-mnt-reform-arm64/updates/dkms/reform2_lpc.ko.xz
Running depmod...... done.
Autoinstall on 6.14.6-mnt-reform-arm64 succeeded for module(s) reform2_lpc.
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-6.14.6-mnt-reform-arm64
Using DTB: freescale/imx8mp-mnt-pocket-reform.dtb
Installing /usr/lib/linux-image-6.14.6-mnt-reform-arm64/freescale/imx8mp-mnt-pocket-reform.dtb into /boot/dtbs/6.14.6-mnt-reform-arm64/freescale/imx8mp-mnt-pocket-reform.dtb
Installing new imx8mp-mnt-pocket-reform.dtb.
flash-kernel: deferring update (trigger activated)
/etc/kernel/postinst.d/reform-qcacld2:
Starting background process to update reform-qcacld2 driver package (for Wi-Fi) to match kernel version.
/etc/kernel/postinst.d/zz-flash-kernel:
Taking backup of imx8mp-mnt-pocket-reform.dtb.
Setting up reform-qcacld2-6.14.6-mnt-reform-arm64 (20250511T124839Z) ...
Setting up linux-headers-6.14.6-mnt-reform-arm64 (6.14.6-1~exp1+reform20250508T045900Z) ...
Setting up linux-image-mnt-reform-arm64 (6.14.6-1~exp1+reform20250508T045900Z) ...
Setting up linux-headers-mnt-reform-arm64 (6.14.6-1~exp1+reform20250508T045900Z) ...
Setting up reform-qcacld2 (20250511T124839Z) ...
Processing triggers for flash-kernel (3.109+reform20250506T203207Z1) ...
flash-kernel: installing version 6.14.6-mnt-reform-arm64
Generating boot script u-boot image... done.
Taking backup of boot.scr.
Installing new boot.scr.
also…
$ sudo reform-check
I: `uname -a` output: Linux mntpr-0 6.14.6-mnt-reform-arm64 #1 SMP Debian 6.14.6-1~exp1+reform20250512T085505Z (2025-05-12) aarch64 GNU/Linux
I: Version of linux-image-mnt-reform-arm64: 6.14.6-1~exp1+reform20250512T085505Z
I: Version of reform-tools: 1.72-1+reform20250508T045900Z1
W: Suggests of reform-desktop-minimal is not installed: firmware-iwlwifi
What happens if you run this:
apt install --simulate reform-desktop-minimal
Hello @josch,
Oh, as it has been my routine to run apt update; apt upgrade when I have a time to do in the mornings. One of the days in the past reform-desktop-minimal was installed and did not postpone any more. I do not recall which day exactly.
Sorry, I did not follow up on this one.
Thank you for checking.
