I did see this was an issue on others pocket reforms. Recently the charging has occasionally got stuck at a specific percentage of battery and wouldn’t charge beyond it. I did the cycling from 0 to 100% a few times but now it has got stuck lower when charging from 0. Is there anyway to solve this as I found no method other than cycling.
Are your firmware versions up-to-date?
Yes they are. Well I used the method using curl to download them from mnt.re. (I appreciate the response!)
What version are you on? These days, you can automatically update them using fwupd or gnome-firmware. Running sudo reform-check will tell you which version you have.
It is the latest one, 20251001.
