Battery indicator, weird icon
Hi all. I have an interesting issue with the battery indicator on swaybar, on my Pocket Reform. When the battery level is between 59% and 40% the battery icon turns into a letter L with stroke ( Ł). :slightly_smiling_face: Anybody experiencing a similar issue? Or have suggestions on how to fix it? Thanks!
Yes, I have that too. Never really understood what’s going in there
The icons are chosen based on your waybar configuration. Have a look at the setting “format-icons” in the section “battery” in ~/.config/waybar/config. What does it say there for you? Mine looks like this:
"format-icons": ["", "", "", "", ""],
My firefox renders these icons this way:
Screenshot 2025-04-24 at 16-20-08 Battery indicator weird icon - MNT Pocket Reform - MNT Research Community
If I copypaste the line into libreoffice and choose “FontAwesome” as the font, then it looks like this:
screenshot-2025-04-24-16-20-43
Do you have the Font Awesome font installed? How does your “format” string in the “battery” section of your waybar config look like?
Thanks for the detailed explanation josch. I looked at the icons battery section in the config file and it looks exactly like you explained here: "format-icons": ["", "", "", "", ""]
When I paste it to LibreOffice and choose FontAwesome font, they look OK too. It seems like I have FontAwesome installed.
Good. Then this must mean that despite the font being installed, it is not getting chosen by waybar.
My whole battery section looks like this:
"battery": {
        "format": "{icon} {capacity}%",
        "format-charging": " {capacity}%",
        "format-plugged": " {capacity}%",
Can you try to change the “format” line to this:
"format: "<span face='FontAwesome'>{icon}</span> {capacity}%",
And then reload waybar.
That fixed it, thank you so much, no more Ł! :slightly_smiling_face:
(Just needed to add a quotation mark after format)
"format": "<span face='FontAwesome'>{icon}</span> {capacity}%",
Whoops, yes the quotation mark was missing.
Do you get the same result if you write “Font Awesome” with a space between “Font” and “Awesome” or does it have to be “FontAwesome”?
Font Awesome (with a space between) seems to also work!
Thank you! Future system images will have this fixed via this commit: etc/skel/.config/waybar/config: explicitly choose FontAwesome via <span> for battery icon (8fe7187a) · Commits · Reform / reform-system-image · GitLab
I had to change the other lines as well to make it work for all states:
"battery": {
        "format-charging": "<span face='FontAwesome'></span> {capacity}%",
        "format-plugged": "<span face='FontAwesome'></span> {capacity}%",
Thank you! Fixed via this commit: etc/skel/.config/waybar/config: explicitly select FontAwesome also for... (01115963) · Commits · Reform / reform-system-image · GitLab
