BFG9060 and ZZ9000 - cold start problem
  • Amiga model: 4000d rev 2
  • 680x0 CPU: 68060
  • RAM Configuration : 16MB Fast RAM onboard, plus zz9000 & BFG memory
  • Kickstart, AmigaOS Versions: 3.2.2 kickstart and OS
  • ZZ9000 Firmware version: 1.13 full version.
  • ZZ9000 Driver version:
  • Monitor model: Dell U2940
  • Other Zorro cards: Buddha IDE
Hi, I have a weird issue in my A4000d whereby after switching on the machine will only boot after an additional 3 fingered salute.
It only manifests itself with the zz9000 - the machine without the zz9000 and with the BFG works fine.
With a 68030 processor card I dont have any issues at all with the zz9000.
The issue is only as a combination of both cards. I even tried an alternate BFG - same issue.
I have tried an alternate slot for the zz9000 - no change there.
Any advice would be appreciated!
I just got my ZZ9000 and have basically the same setup as you.
I also had the same issue. I found via a Google search an answer to this problem on this very Forum.
You have to copy MuMove4K from MuTools (search Aminet). Then place a line in your Startup-Sequence just before Setpatch. So for example:
Work:C/MuMove4K
Setpatch
This solved my problem and i have been ā€˜seeing’ the ZZ9000 on 1st boot.
Hi - Thanks! Since the CPU isnt going high until I soft reset then a software fix in Startup-Sequence isnt going to work.
I tried it anyway ofc.
Between the BFG and ZZ9000 I have some kind of ā€œholdā€ prior to the soft reset. Still no idea why!
I spotted this on Amibay, there is an update you can easily do to the BFG’s Flash.
Look at Post #69:
Careful there… The post is from 2022 - chances are that if you have a newer BFG you might break something - The fix would already be in place
Yeah, its tempting - but Ill contact the builder of the BFG first I think. The description of the problem is exactly the issue I have though, which is interesting. Right now, a three fingered salute isnt the end of the world - and once booted the A4000 is rock solid. Ive another ZZ9000 on order - so Ill be swapping it over also, just to see if the problem follows the card.
