Hello all, first of all, I want to thank you for this forum.
I am so happy I finally bought a mnt Pocket Reform off of eBay and now I was wondering if I can upgrade the arm cortex processor?
Also what should I be concerned about?
I think it was the first revision I bought.
I currently had 8GB can I upgrade the ram?
I’d love to see a handbook, which one is suitable for this?
Anything else I should be aware of?
Also: if I mess something up, can I order some spare parts or pick them up in Berlin?
As I don’t have a original recipe for it, I was wondering if I get any support or something in case I need replacement parts which aren’t available on the store.
Since you mentioned 8 GB ram, you probably have the version with i.mx8m+. You can find out by looking at the output of:
cat /proc/device-tree/model
These kind of embedded boards (think raspberry pi) have the RAM soldered onto the board, so in contrast to desktop PCs, there are no dedicated RAM bars that you can swap. With RK3588 you can choose between 16 GB or 32 GB of RAM soldered onto the board.
