The good news!
I have managed to install the CPU upgrade and boot off an SD card.
Wifi works! Performance is improved! I can (manually) mount the encrypted NVME drive!
Using reform-emmc-bootstrap seemed to work, and I haven’t soft-locked anything as I can still boot from SD card, but without the SD card the screen stays black and the system is just kind of there – HDMI and eDP screens are both black. The oled control panel is still responsive, as always.
Based on other threads, I’m not actually sure I can successfully boot off of emmc with the A311D board, yet? And there is a risk of soft-lock if I try flashing/reflashing things (which I thankfully haven’t run into yet).
Failing that, I think what I want is a dedicated SD card that’s got my boot partition on it, which mounts my encrypted NVME as the root filesystem (and swap).
Right?
Are these instructions still current?
Is there anything needed to convince the system to always boot using the internal eDP screen, not the HDMI output? It seems to intermittently decide to use the HDMI output instead, and I haven’t figured out the criteria yet…
Thanks for all the help already!
