Burn-in on display?
I left my pocket open with the MNT reform screen for about, well it was probably about 4 or 5 hours, but I was surprised when I came back to it that the Reform website, which is what I had open, was now… overlayed over emacs, very visibly.
Then I powered it off fully and powered it back on hoping it’s a driver issue but nope, it’s still there.
Is burn-in a known issue with these screens? I’m genuinely surprised that seemed to happen so fast?
I’m leaving it off for a while before I turn it back on, but…
Well, I had powered it off and powered it back on immediately earlier when I saw the issue persist. But I powered it off for an hour and back on and… it’s fine! So if you run into this, try powering it off for a bit???
No idea why that would happen but it’s a relief!
Yes, I’ve seen this happen, but as you discovered, this ghosting is not permanent. It’s probably worth investigating swayidle or even a screensaver ^^
Automatic display off would also be nice :slight_smile:
swayidle should be able to do that (with dpms off or brightnessctl).
I’ve added a variant of the sample from Sway - ArchWiki to my config now.
exec swayidle -w \
    timeout 240 'swaymsg "output * power off"' \
    resume 'swaymsg "output * power on"'
Turning the output off is about 200mA on imx8mp :slight_smile:
I tried this on my big reform and I get:
Error: Invalid output subcommand: power.
Seems like on Debian stable the command was still called “dpms power” instead of just “power”. Don’t know about the exact syntax, https://dyn.manpages.debian.org/jump?q=sway-output doesn’t work for me.
From sway-output(5) — sway — Debian unstable — Debian Manpages
output power on|off|toggle
Turns on or off the specified output.
As opposed to the enable and disable commands, the output keeps its current workspaces and windows.
output dpms on|off|toggle
Deprecated. Alias for power.
