These two lines are repeated 8 times. Then nothing for a few minutes and repeated again.
Theses messages appear even no Ethernet cable plugged. And when I plug one, no connections occurs and no LED light. Even with the cable which work with my previous CPU module (the imx8 one)
Does someone have an idea of what I am doing wrong?
this seems to be a regression in reform-tools 1.35 that is fixed in 1.36 which was released today. I’m sorry for the inconvenience! The problem was the set -e in /usr/sbin/reform-hw-setup, which caused the script to break prematurely.
@ephase, @lykso can you make sure that the issue you saw is now fixed? reform-tools with the set -e bug was only available starting yesterday at around 16:00 UTC which is after your messages. Did you maybe accidentally download system images that were not built from the main branch?
@ephase did you also use this link to download the images? https://mnt.re/system-image Let me quote the link with backticks this time so that the forum software doesn’t mangle it…
@minute I was about to suggest that https://mnt.re/system-image could instead point to https://source.mnt.re/reform/reform-system-image/-/releases but it seems that the latest release for sysimage-v4 also just points to https://mnt.re/system-image which in turn redirects to https://source.mnt.re/reform/reform-system-image/-/jobs/3599/artifacts/browse which are the artifacts for the staging branch. Maybe the release page should instead hard-code the artifact URL for each release and then https://mnt.re/system-image can point to the release page or https://mnt.re/system-image should just point to the specific job artifacts of the latest release.
