Hello, I recently received my Pocket Reform, and I’m having a lot of fun with it. However, when I initially ran the setup, I selected the Wayfire desktop, because I wasn’t sure I will be able to use Sway well. I have since then tried Sway and I like it more, but I can’t find where that setting is set. I searched through all the configuration files in the user’s home directory, and I went looking through all the Xsession files in the /etc, trying to figure out where they take their program name from, but I wasn’t successful.
If I try to re-run the setup as a user, switching the desktop type does nothing, at least without the other steps that all fail because of missing permissions.
If I try to re-run the setup as root, it says there is no auth method and fails to start.
Does anybody know where that setting is saved?
