Charging is extremely slow
I got my pocket reform yesterday, after testing I decided to charge it to 100%,I use steam deck charger to charge my pocket reform and for half hour it went from 34% to 36%.
Anyone experienced the same problem?
Update: the red charging light on the right panel show up and battery charging board isn’t hot.
There’s a whole thread about issues with different chargers and recommendation which ones work better: Pocket Reform charging question - #21 by zeha
Hope something works out for you
Looks like mine problem seem to related to this
(Pocket Reform charging question - #6 by yuvadm)
Problem.
The OLED show only -0.05V when charging to 36%, but it show -1.17V when battery is in 28%.
It is probably full charged, but the battery gauge still needs to learn this. Run it from battery until it shuts down. Then it learns the capacity.
Many thanks. This worked.
