Compatibility of the MNT Reform Next and the RKX7
I am considering preordering the MNT Reform Next and my purchase depends on whether it is compatible with the RKX7 SoM. Are these two compatible?
Generally yes. It depends a bit what your goals are with this combination.
I want to create a RISC-V SoC with custom Lisp Extensions. So access to the display, keyboard and storage would be required.
