Debian Stable: Wifi
I want to install Debian Stable on the pocket reform.
Thanks to https://reform.debian.net/ there is an image, but wifi is not working.
Has somebody figured it out? Or what log can I post to help?
You are missing the firmware. The package containing the firmware is called ezurio-qca-firmware and has been sitting in NEW since the beginning of July this year: Debian NEW and BYHAND Packages
There is little that can be done to speed up FTP-master review…
Thanks! plus some characters
You also could put the firmware files in place manually.
Or you build the package from source for yourself using: Debian / ezurio-qca-firmware · GitLab
The latest salsa pipeline also has a package in case you want to try that: debian/output · Artifacts · build (#5933042) · Jobs · Debian / ezurio-qca-firmware · GitLab
