Deciphering Pocket Reform Models on Mouser
Hi All,
I’m looking to get a Pocket Reform from Mouser, but can’t determine which is which. I want to get the hyper-purple Pocket Reform with the linear switches and see two different Hyper-purple versions on Mouser. See below
PREF-HYPRWT-V10-R01
PREF-HYPRRD-V10-R01
Looking at the descriptions for each, I can’t tell the difference.
Can anyone here or from the MNT team tell me which has the linear switches, if any?
Thanks,
G3M
wt is white switch
rd is red
Your choice of Kailh Choc White (clicky 50g) or Kailh Choc Pro Red (light linear 35g) switches
Exactly what I was looking for.
Cheers & Thanks,
G3M
I assume this also comes with the standard i.MX8MP module? What about the SSD?
It’s so strange that Mouser doesn’t list the specs.
Following up to answer my own question. It looks like this is correct. The listing doesn’t show this, but the abstract in the list of available versions shows this as the module.
Yes this includes the SSD 1TB, a case/sleeve, a printed manual and a lithograph.
Thanks for the help. I pulled the trigger and looking forward to my Pocket Reform.
