Hi!
On reform.debian.net stable, when installing linux-image-6.17.8+1-mnt-reform-arm64, the build of reform2_lpc fails with the following output:
DKMS (dkms-3.2.2) make.log for reform2_lpc/1.76 for kernel 6.17.8+1-mnt-reform-arm64 (aarch64)
mån 1 dec 2025 12:10:13 EET
Building module(s)
command: make -j8 KERNELRELEASE=6.17.8+1-mnt-reform-arm64 -C /lib/modules/6.17.8+1-mnt-reform-arm64/build M=/var/lib/dkms/reform2_lpc/1.76/build
make: Går till katalogen ”/usr/src/linux-headers-6.17.8+1-mnt-reform-arm64”
make[1]: Går till katalogen ”/var/lib/dkms/reform2_lpc/1.76/build”
CC [M] reform2_lpc.o
reform2_lpc.c: In function ‘lpc_probe’:
reform2_lpc.c:200:17: error: ‘struct power_supply_config’ has no member named ‘of_node’; did you mean ‘fwnode’?
200 | psy_cfg.of_node = spi->dev.of_node;
| fwnode
make[3]: *** [/usr/src/linux-headers-6.17.8+1-common/scripts/Makefile.build:292: reform2_lpc.o] Fel 1
make[2]: *** [/usr/src/linux-headers-6.17.8+1-common/Makefile:2035: .] Fel 2
make[1]: *** [/usr/src/linux-headers-6.17.8+1-common/Makefile:260: __sub-make] Fel 2
make[1]: Lämnar katalogen ”/var/lib/dkms/reform2_lpc/1.76/build”
make: *** [/usr/src/linux-headers-6.17.8+1-common/Makefile:260: __sub-make] Fel 2
make: Lämnar katalogen ”/usr/src/linux-headers-6.17.8+1-mnt-reform-arm64”
exit code: 2
elapsed time: 00:00:03
Cheers!
