I’ve been trying to modify the Pocket Reform keyboard firmware to turn one of the Space keys into a Compose key, but I’m stuck at trying to get the dependencies to install. Here’s the output from running ./install-fw-dependencies.sh:
+ set -- build-essential gcc-arm-none-eabi libnewlib-arm-none-eabi libstdc++-arm-none-eabi-newlib libusb-1.0-0-dev cmake python3 gcab cppcheck
+ '[' '' = true ']'
+ set -- build-essential gcc-arm-none-eabi libnewlib-arm-none-eabi libstdc++-arm-none-eabi-newlib libusb-1.0-0-dev cmake python3 gcab cppcheck tio picotool
+ set -- apt-get --update --no-install-recommends -y install build-essential gcc-arm-none-eabi libnewlib-arm-none-eabi libstdc++-arm-none-eabi-newlib libusb-1.0-0-dev cmake python3 gcab cppcheck tio picotool
+ '[' 1000 '!=' 0 ']'
+ set -- sudo apt-get --update --no-install-recommends -y install build-essential gcc-arm-none-eabi libnewlib-arm-none-eabi libstdc++-arm-none-eabi-newlib libusb-1.0-0-dev cmake python3 gcab cppcheck tio picotool
+ echo 'Running sudo' apt-get --update --no-install-recommends -y install build-essential gcc-arm-none-eabi libnewlib-arm-none-eabi libstdc++-arm-none-eabi-newlib libusb-1.0-0-dev cmake python3 gcab cppcheck tio picotool
Running sudo apt-get --update --no-install-recommends -y install build-essential gcc-arm-none-eabi libnewlib-arm-none-eabi libstdc++-arm-none-eabi-newlib libusb-1.0-0-dev cmake python3 gcab cppcheck tio picotool
+ sudo apt-get --update --no-install-recommends -y install build-essential gcc-arm-none-eabi libnewlib-arm-none-eabi libstdc++-arm-none-eabi-newlib libusb-1.0-0-dev cmake python3 gcab cppcheck tio picotool
Hit:1 http://deb.debian.org/debian unstable InRelease
Hit:2 http://download.opensuse.org/repositories/shells:/fish:/release:/4/Debian_Unstable InRelease
Get:3 https://apt.syncthing.net syncthing InRelease [24.2 kB]
Ign:4 https://mntre.com/reform-debian-repo reform InRelease
Hit:5 https://mntre.com/reform-debian-repo reform Release
Ign:6 https://mntre.com/reform-debian-repo reform Release.gpg
Fetched 24.2 kB in 0s (65.7 kB/s)
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
picotool is already the newest version (2.2.0-a4+dfsg-3).
Solving dependencies... Error!
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
build-essential : Depends: g++ (>= 4:14.2) but it is not going to be installed
cmake : Depends: cmake-data (= 4.2.3-1) but it is not going to be installed
Depends: librhash1 (>= 1.2.6) but it is not going to be installed
cppcheck : Depends: libtinyxml2-11 (>= 11.0.0) but it is not going to be installed
Depends: python3-pygments but it is not going to be installed
gcab : Depends: libgcab-1.0-0 (>= 1.4) but it is not going to be installed
gcc-arm-none-eabi : Depends: binutils-arm-none-eabi but it is not going to be installed
libnewlib-arm-none-eabi : Depends: libnewlib-dev (= 4.5.0.20241231-1) but it is not going to be installed
libstdc++-arm-none-eabi-newlib : Depends: libnewlib-dev but it is not going to be installed
Depends: libstdc++-arm-none-eabi-dev (= 15:14.2.rel1-1+29) but it is not going to be installed
Depends: gcc-arm-none-eabi (= 15:14.2.rel1-1) but 15:14.2.rel1-1+b1 is to be installed
libusb-1.0-0-dev : Depends: libusb-1.0-0 (= 2:1.0.29-2+b1) but 2:1.0.29-2 is to be installed
python3 : PreDepends: python3-minimal (= 3.13.9-3) but 3.13.9-2 is to be installed
Depends: libpython3-stdlib (= 3.13.9-3) but 3.13.9-2 is to be installed
N: Missing Signed-By in the sources.list(5) entry for 'https://mntre.com/reform-debian-repo'
N: Missing Signed-By in the sources.list(5) entry for 'http://download.opensuse.org/repositories/shells:/fish:/release:/4/Debian_Unstable'
E: Unable to satisfy dependencies. Reached two conflicting decisions:
1. libstdc++-arm-none-eabi-newlib:arm64=15:14.2.rel1-1+29 is selected for install
2. libstdc++-arm-none-eabi-newlib:arm64 Depends gcc-arm-none-eabi (= 15:14.2.rel1-1)
but none of the choices are installable:
[no choices]
I was planning to raise this as an issue on Gitlab, but I don’t know if you want external people in there – feel free to reject my request for a use account over there.
