Favor/Request: PassMark Performance Test Suite on A311D
I am still gathering information and trying to plan how I might get into the MNT Reform ecosystem, but I am not finding any benchmarks on CPUBenchmark.net for the A311D that comes as the stock system board for the MNT Reform/Pocket.
I have found benchmarks for all my current systems, systems I am cross-shopping, and the CPUs in the other MNT Reform boards (RK3588 and imx8), so I have good book-ends, but not that base board I might use as my entrypoint.
So, I am wondering if anyone has the bandwidth to give this suite a run and submit the results so that I can add the A311D into my benchmark table to help me compare.
Thanks for your consideration!
Hello,
would you be so kind to share the benchmarks you found for RK3588 and imx8?
Regards.
Sure!
I am not sure if any of the aggregated benchmarks came from MNT Reform devices, but at the least, these SOCs are present:
https://www.cpubenchmark.net/compare/5544vs4906/nxp-IMX8MQ-vs-Rockchip-RK3588
Here you go: PassMark Software - Display Baseline ID# 5074034
Sweet, thank you so much!
That puts A311D about 20-25% slower than my current N3450, which is something to think about, whereas the RK3588 is more than twice as fast.
