"Grave bugs..." installing libreoffice
On unstable with original source.list, apt install libreoffice reports grave bugs. Did not proceed with install.
Not sure how to proceed with problems like this. If it were an update I’d just wait and see.
Fetched 268 MB in 1min 1s (4,376 kB/s)
serious bugs of openjdk-17-jre-headless (→ 17.0.11~7ea-1+b1) <Outstanding>
 b1 - #1057715 - openjdk-17: missing symbol on i368 in libjvm
grave bugs of libreoffice-core (→ 4:24.2.2-3+b1) <Forwarded>
 b2 - #935182 - Concurrent file open on the same host results file deletion
Summary:
 openjdk-17-jre-headless(1 bug), libreoffice-core(1 bug)
Are you sure you want to install/upgrade the above packages? [Y/n/?/...] n
The title of bug #1057715 indicates, that you will not be affected because the bug is limited to i386 and you are on arm64.
Reading the discussion of https://bugs.debian.org/935182 it seems that the bug has been present since 2019 and it only happens if two users on the same computer open the same file from a samba share.
Sheesh. OK again a problem I could have probably solved myself. I’ll read more closely.
why does it even report the existence of the bug if its specific to a different arch? It’s hardly relevant to the user in that case.
