Guix and Reform
@lykso I don’t know if you already are collaborating with @vagrantc ?
I’m currently struggling with getting u-boot to work for my imx8mp pocket reform. So far I’ve tried to:
(define-public u-boot-imx8mp-reform-bin
  (package
    (name "u-boot-imx8mp-reform-bin")
    (version "2025-01-12")
    (source (origin
              (method url-fetch)
              (uri "https://source.mnt.re/reform/reform-imx8mp-uboot/-/jobs/7404/artifacts/raw/imx8mp-mnt-pocket-reform-flash.bin")
              (sha256 (base32 "1avydp0643hq12y057iyaqwzbb4in66wbakj3jc53gg75k7f044c"))
              (file-name "imx8mp-mnt-pocket-reform-flash.bin")))
    (build-system copy-build-system)
    (arguments
     `(#:install-plan '(("imx8mp-mnt-pocket-reform-flash.bin" "bin/"))))
    (native-inputs (list coreutils))
    (home-page "https://source.mnt.re/reform/reform-imx8mp-uboot")
    (synopsis "Prebuilt U-Boot binaries for MNT Reform i.MX8MP")
    (description "This package provides prebuilt U-Boot binaries for Pocket Reform devices based on the i.MX8MP processor.")
    (license gpl2+)))
(define install-pocket-reform-bootloader
  #~(lambda (bootloader root-index image)
      (let ((u-boot (string-append bootloader
                                   "/bin/imx8mp-mnt-pocket-reform-flash.bin")))
        (write-file-on-device u-boot (stat:size (stat u-boot))
                              image (* 8 1024)))))
(define imx8mp-bootloader
  (bootloader
   (inherit u-boot-bootloader)
   (package u-boot-imx8mp-reform-bin)
   (disk-image-installer install-pocket-reform-bootloader)))
(operating-system
  (bootloader (bootloader-configuration
                (bootloader imx8mp-bootloader)))
simply use copy-build-system for the boot loader package, as well as another approach which builds u-boot from a local u-boot fork that has every steps and patches from the .gitlab-ci.yml · main · Reform / MNT Reform i.MX8MPlus U-Boot Build · GitLab applied:
(define-public install-imx8mp-u-boot
      (let ((u-boot (string-append bootloader "/libexec/flash.bin")))
                                image (* 33 1024)))))
  (let ((base (make-u-boot-package
                "nitrogen8mp"
                "aarch64-linux-gnu"
                #:defconfig "imx8mp-mnt-pocket-reform_defconfig")))
  (package
      (inherit base)
      (source (local-file "/home/willow/devel/u-boot" #:recursive? #t))
      (inputs (modify-inputs (package-inputs base)
        (append openssl)))
        (arguments
          (substitute-keyword-arguments
            (package-arguments base)
            ((#:phases phases '%standard-phases)
             #~(modify-phases #$phases
                              (replace 'configure
                                       (lambda* (#:key make-flags #:allow-other-keys)
                                       (copy-file "imx8mp-mnt-pocket-reform_defconfig" ".config")))
                              (replace 'build
                                         (apply invoke "make" `(,@make-flags "flash.bin")))))))))))
(define-public u-boot-imx8mp-bootloader
  (bootloader
    (disk-image-installer install-imx8mp-u-boot)
    (package u-boot-imx8mp)))
(operating-system
                (targets '("/dev/mmcblk0"))
                (bootloader u-boot-imx8mp-bootloader)))
in both cases I’m unable to boot guix and it seems to fall back to the emmc (given I get a initramfs REPL after a systemd related message). The u-boot package does seem to look fine though:
~/devel/u-boot$ ls /gnu/store/58kn7bh3192lz1bwfym4bm1v9phrnxcc-u-boot-nitrogen8mp-2025.01/libexec
arch             bl31-iMX8MQ.bin      bl31-tee-iMX8MP.bin   dts          lpddr4_pmu_train_1d_dmem_202006.bin  scripts         tools           u-boot-nodtb.bin    u-boot.img
bl31-iMX8MM.bin  bl31-iMX8ULP.bin     bl31-tee-iMX8MQ.bin   flash.bin    lpddr4_pmu_train_1d_imem_202006.bin  spl             u-boot          u-boot-spl-ddr.bin  u-boot.itb
bl31-iMX8MN.bin  bl31-tee-iMX8MM.bin  bl31-tee-iMX8ULP.bin  itb.fit.itb  lpddr4_pmu_train_2d_dmem_202006.bin  spl.bin         u-boot-dtb.bin  u-boot.bin
bl31-iMX8MP.bin  bl31-tee-iMX8MN.bin  doc                   lib          lpddr4_pmu_train_2d_imem_202006.bin  tee-imx8mp.bin  u-boot-dtb.img  u-boot.dtb
so I suspect, it’s either me messing up the offset or the targets or something along those lines?
Please be careful with flashing a custom u-boot to eMMC of imx8mp. Flashing a non-working u-boot may soft brick your device. In case this happens, unbricking it is a bit more involved: Flashing eMMC Bootloader / Unbricking (IMX8MP)
Originally, flashing a different u-boot wasn’t even a thing that was considered to be a feature by MNT unless you really, really, really knew what you were doing: 2024-08-04.log
That’s why for a long time, reform-flash-uboot would completely disallow flashing u-boot on imx8mp. These days, it will let you flash it but only if the hash matches the known latest one and even then only with a big fat warning.
Even with the stock u-boot on eMMC, that u-boot will first try to read boot.scr or extlinux.conf from the first partition of your sd-card. It does not matter that u-boot is on eMMC. The sd-card will be tried first. It does not matter where your u-boot got loaded from and imx8mp cannot load u-boot from your sd-card. So if the stock u-boot does not load your system on sd-card, then you might’ve misconfigured boot.scr or extlinux.conf on your sd-card.
You probably have a UART adapter to figure out what is going on early in the boot process? If yes, please post some output so that we can figure out why it still boots your system on eMMC instead of your system on sd-card. If no, I would really not recommend you flash your custom u-boot image to emmc…
Thanks for the in-depth explanation and the word of warning regarding putting a custom u-boot on emmc! I think:
is where my generated image is faulty, it seems to have a EFI partition:
fdisk -l /gnu/store/baqznidcfg10gc5q03a53fgn26vv783d-disk-image
Disk /gnu/store/baqznidcfg10gc5q03a53fgn26vv783d-disk-image: 2.18 GiB, 2345885696 bytes, 4581808 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x00000000
Device                                                  Boot Start     End Sectors  Size Id Type
/gnu/store/baqznidcfg10gc5q03a53fgn26vv783d-disk-image1       2048   83967   81920   40M ef EFI (FAT-12/16/32)
/gnu/store/baqznidcfg10gc5q03a53fgn26vv783d-disk-image2 *    83968 4581807 4497840  2.1G 83 Linux
that’s not needed and shouldn’t be there. Guix does have other image-types (image-type Reference (GNU Guix Reference Manual)), so I’m currently trying my luck with raw-with-offset-image-type as that only generates an image with one partition. The boot/extlinux/extlinux.conf seems to be correctly generated at least.
If I read this correctly, I don’t have to build my own u-boot as a part of the sd-image then? and probably am able to rely on the stock u-boot to find boot/extlinux/extlinux.conf on my sdc and boot up guix? that’d be pretty cool, always assumed I had to build u-boot myself and put it on the sdc.
Edit: So with the single-partition image I get:
Warning: Type of root filesystem is unknown, so skipping check.
mount: mounting 38af4c98-533d-621b-e9fd-c91338afc93 on /root failed. No such file or directory.
Failed to mount 38af4c98-533d-621b-e9fd-c91338afc93 as root file system.
and then I’m dropped to initramfs. Was able to verify that the UUID matches the SDC partition:
/dev/mmcblk0p1: LABEL="Guix_image" UUID="38af4c98-533d-621b-e9fd-c91338af4c98" BLOCK_SIZE="4096" TYPE="ext4"
think I may have to use a different image type in the guix system image vommand/maybe a different offset?
That is correct. The imx8m+ will not try to read u-boot from the sd-card, so flashing u-boot onto the sd-card is pointless. Stock u-boot from eMMC will find your /extlinux/extlinux.conf from the first partition on your sd-card and then you “just” need to have that extlinux.conf set up with the correct parameters to continue booting.
How does the uuid match? From the error output, your uuid is:
But in your second command, the uuid is:
The two are not the same.
Finally succeeded in running Guix System on my pockets NVMe and wrote a note on how I did it in case more people are interested in it: Installing And Running Guix System On (rk3588) MNT Pocket Reform -- literatelisp.eu
Nice work @theesm! After reading your blog post I have the following remarks:
  • you rely on the recent change of u-boot boot order. Today in IRC we were close to reverting the change because some users report that with that u-boot their NVMe SSD doesn’t come online anymore. If you experience any issue with that u-boot version and your SSD please post your dmesg output
  • how hard would it be to create a bootable sd-card with guix on a non-guix system like debian?
  • you may want to have a look at the reform-hw-setup script which is run once on boot to set up a few things (like audio)
thanks for reading and taking the time to share your remarks!
haven’t experienced any issues with my SSD and the latest u-boot (using a Kingspec NE-256 SSD) so far but I’ll let you know if that changes.
to create a microSD image only guix as a package manager is required (one doesn’t need a running guix system OS to do so). Installing guix as a package manager is quite easy on a debian system, there’s even a package for that in upstream debian I think. As soon as this requirement is met one could create a microSD image via the guix system image command (see https://guix.gnu.org/manual/devel/en/html_node/Instantiate-an-Image.html) passing a valid configuration to it, ddit to a microSD and reboot into guix system.
that’s pretty useful, thanks!
I run guix as a package manager on my Pocket Reform as a matter of routine; I bootstrapped with the Debian guix package (although I do not do this on all of my systems). It works fine business.
I’ll try making a guix SD card image when I get a chance, I would love to be able to use guix system on my PR.
Debian removed guix recently.
I have had fun with this, and gotten exwm working. This was a bit of trial and error, which I would like to share in case it is of use to someone else.
As a fun easter egg, GDM kind of works, but does not (most of the time) display anything. It captures input so we can log in blindly or tell it to autologin. With GDM we can (at least on the rockchip) use X11. The display will be rotated 90 degrees clock-wise, which is easy to fix.
(define pocket-rotate-display "
Section \“Monitor\”
Identifier \“DSI-1\”
Option \“Rotate\” \“Left\”
EndSection")
(modify-services %desktop-services
(gdm-service-type
config =>
(gdm-configuration
(inherit config)
(xorg-configuration
(xorg-configuration
(extra-config (list pocket-rotate-display))))
(auto-login? #t)
(default-user “torb”))))
I have not been able to set the xorg keyboard-layout to “eu” #:options '(“lv3:ralt_switch”) (which works in the system console). Instead I use setxkbmap from the package of the same name.
Again, thanks theesm for the great work!
I just joined this forum after seeing someone documenting a NixOS installation on Pocket. However, I’m so glad Gnu Guix is possible as well because I have plans to move to the latter long term. Thank you for documenting your experience. :grin:
Is this correct to assume this would only work on the Pocket so far? No one has tried it on the other two laptops, right?
Guix should run on most MNT laptops, I’ve mostly seen it running on pocket reforms (my own rk3588 pocket reform and a small number of others people brought to guix days this year) though.
iirc @vagrantc uses a non-pocket reform running guix.
The linux-libre-arm64-mnt-reform-7.0 package in guix currently includes these dts so if you have one of those configurations it may work:
  • “amlogic/meson-g12b-bananapi-cm4-mnt-pocket-reform.dts”
  • “freescale/fsl-ls1028a-mnt-reform2.dts”
  • “freescale/imx8mp-mnt-pocket-reform.dts”
  • “freescale/imx8mp-mnt-reform2.dts”
  • “freescale/imx8mq-mnt-reform2-hdmi.dts”
  • “rockchip/rk3588-mnt-desktop-reform.dts”
  • “rockchip/rk3588-mnt-pocket-reform.dts”
  • “rockchip/rk3588-mnt-reform-next.dts”
  • “rockchip/rk3588-mnt-reform2.dts”
  • “rockchip/rk3588-mnt-reform2-dsi.dts”
Running it as a foreign-distro package manager on top of the reform image on the pocket reform is easy. Only issue, after installing applications they are not visible in the gnome application search. I mean you can type in the name of the application in a terminal and run them. However, it is difficult to remember the binary name of every applications.
That’s most certainly due to the XDG_DATA_DIRS env variable not including guixes entries. I believe that setting:
export XDG_DATA_DIRS="~/.guix-profile/share:$XDG_DATA_DIRS"
in your .profile may help with that. (if you’re using guix home ~/.guix-home/profile/share should also be added)
I doubt that ~ is expanded to the home directory in XDG_DATA_DIRS. Can you confirm?
I think you’re right about the expansion not working, my XDG_DATA_DIRS also contains a full path (/home/username/.guix-profile…). I don’t have to set it manually though as I’m running guix as my OS not as a foreign standalone package manager.
