HDMI audio output on i.MX8MP
Hello everyone!
Not sure if I’m beating a dead horse here (sorry if this has been covered already!), but I’ve been digging through the forum and couldn’t find anything on this.
I’m trying to get the audio from my Pocket Reform i.MX8MP to run through the HDMI port to my TV, but I’m having no luck. Has anyone else run into this? Is it supposed to work out of the box, or is it just not possible with this SoC?
Thanks a ton for the help.
In case it helps, here’s my reform-check output:
I: `uname -a` output: Linux pocket 6.18.10-mnt-reform-arm64 #1 SMP PREEMPT Debian 6.18.10-1+reform20260215T065736Z (2026-02- aarch64 GNU/Linux
I: Version of linux-image-mnt-reform-arm64: 6.18.10-1+reform20260215T065736Z
I: Version of reform-tools: 1.84-1+reform20260128T083307Z+1
I: Version of system image: System Image v5: 2026-01-27
I: To retrieve the latest sysctl and keyboard firmware versions either install libxmlb-utils or install curl, xz-utils and libxml2-utils
I: Version of system controller firmware: 20251030
I: Version of keyboard firmware: 20251030
I: Version of LPC firmware: PREF1SYS R1 20251030
I: Version of upstream U-Boot: 2022.04
I: Version of MNT U-Boot: 2026-01-28
W: reform_crypt LUKS device on unusual disk: /dev/mmcblk2p2
I: Mount source of /: /dev/reformvg/root (n.a.)
I: Install the package shellcheck for checking /boot/boot.scr fI: Contents of /proc/device-tree/model: MNT Pocket Reform with i.MX8MP Module
I: Install the package shellcheck for checking /boot/boot.scr for problems
 + console=ttymxc1,115200
I: kernel boot parameters which are the default but your system I: Contents of /proc/device-tree/model: MNT Pocket Reform with i.MX8MP Module
 - console=ttymxc1
W: reform-setup-wizard failed to clean up /etc/profile.d/reformI: Contents of /proc/device-tree/model: MNT Pocket Reform with i.MX8MP Module
 - console=ttymxc1
W: reform-setup-wizard failed to clean up /etc/profilI: Contents of /proc/device-tree/model: MNT Pocket Reform with i.MX8MP Module
 - console=ttymxc1
W: reform-setup-wizard failed to clean up /etc/profile.d/reform-setup.sh. It can be safely removed.
I: eMMC contains the latest u-boot version 2026-01-28e.d/reform-setup.sh. It can be safely removed.
I: eMMC contains the latest u-boot version 2026-01-28-setup.sh. It can be safely removed.
I: eMMC contains the latest u-boot version 2026-01-28doesn't use them:
 - console=ttymxc1
I: eMMC contains the latest u-boot version 2026-01-28or problems
 - console=ttymxc1
We haven’t been testing audio thru HDMI, and I don’t know if that’s even possible with how everything is wired.
OK! thank you @wakest
