Hibernate on rk3588
I thought I should start a separate thread for discussion of hibernation on the rk3588. After talking to gordon1 on IRC, I started working my way through
Debugging hibernation and suspend — The Linux Kernel documentation
I didn’t get too far, you can see my notes so far at
Hibernate on the pocket reform 2/n
I’m currently waiting for a UART/USB adapter plan to see if I can see anything interesting on the serial console when running the “platform” test.
I am of course open to other ideas.
A small update. I got serial console working, and obtained a log from the pocket reform failing to resume. It seems to be related to pcie. Details at
In the last week or so I have been working on getting a current kernel working with the existing reform patches.
I have a 6.16~rc6 kernel (based on collabora sources) booting, but the LCD screen is inactive: A little backlight but no tui-greet.
There are (many) details at
Updated to show relevant seeming warnings from DTS compilation.
I’m a bit stuck with this device tree business, so I filed an issue
EDIT: Issue is resolved, panel is working.
I did eventually manage to get the PCI reset series applied, but it did not seem to fix the problem with the “platform” test
Details (mainly logs) at
I have slowed down on this, but I continue to track Collabora’s rockchip-devel branch and test hibernation. Unfortunately the PCI reset series (not yet in mainline) that several people thought might help does not apply easily anymore.
https://www.cs.unb.ca/~bremner/blog/posts/hibernate-pocket-13/
