How is Suspend/Resume on the RK3588?
I currently have a Reform with the A311D installed. I love it and I use it all the time, but the only thing keeping it from being a true daily driver is the lack of solid suspend/resume support. I know it works for some people but my system will not wake after I suspend it. This seems to be a known problem with how the clocks are configured.
It sounds like the RK3588 has much better Linux support. How is suspend resume working for that one? I will definitely order one if it means I can put my laptop to sleep.
I checked some Chinese forums and suspend and resume does supported on rk3588, but there isn’t much information about how well suspend and resume worked on rk3588.
From CSDN
Linux kernel mailing list also mentioned suspend and resume on rk3588
https://lore.kernel.org/linux-arm-kernel/20230604112745.402beb1c@jic23-huawei/T/
Sounds like hope is not lost! Thank you for posting, I will take a look
Hello! Feels worthwhile reviving this thread. I personally just got an rk3588 on my pocket reform, and of course the new Reform Next is coming out using rk3588 modules by default.
Suspending/resuming feels like the biggest blocker on having these devices be easy to travel around with. I’m curious, @kaybarkbark did you look further at the patch series? Did anyone else?
Hello again! Which patch series are you referring to? Are there patches for the Amlogic or Rockchip chipset? I am currently dealing with a critical lack of spoons but perhaps I can find the energy to give them a try.
Ah I meant [PATCH v3 0/8] RK3588 ADC support linked above! Though… tbh I wouldn’t know what to do with it, and it’s a bit hard for me to tell with LKML whether those patches were merged, etc
It’s a-ok if you don’t have the spoons to deal with it also! Prioritize your own well being <3
At least one user on the fediverse reports that they have working suspend on the RK3588 Akkoma
Bump. Is suspend/resume functional on the latest available kernel from MNT sources (6.14, if I’m looking at the correct repository)?
No.
You can talk to gordon1 in the IRC channel to work on this. Last update here: 2025-04-30.log
I wish I had more skills to follow up on this directly. I have been using my Pocket a bit more, and am excited about the Reform Next, but I think this is the thing that’s keeping the device from being something I reliably just carry around with me and use spontaneously. I suspect for many others too, and I suspect it’s the main thing that will be the key factor for whether the Reform Next manages to become a daily driver for many people.
I don’t really have any kernel hacking skills, so I’m not sure how I can help. But maybe if someone made a build with one of the kernels which supposedly has suspend, I can help by testing? If anyone has ideas on ideas of how a kernel-naive person with not much time but still having an interest in assisting can help things move along, I’d like to be helpful somehow.
@minute gave a helpful followup on the fediverse for what next steps could be:
There’s one person who has (IIRC) working hibernate, gordon1 in the IRC channel. if i were to debug suspend, i’d make a custom boot disk with extlinux.conf enabling some kernel parameters like no_console_suspend, and make a custom dtb file with as many hardware features as possible turned off but that i’d still be able to boot to a console where i can try the suspend/resume. i think it should work with bare rk3588 + serial console, for example. then enable hw features one by one to see which ones cause suspend or wakeup to get stuck.
