@josch I tested both the reform-flash-uboot script and the flash.bin from the MR linked (I used this artifact).
TL;DR is that both work correctly on my Pocket Reform with IMX8MP, with a couple of small notes below.
For reform-flash-uboot, I installed a fresh copy of the latest Pocket Reform system image for IMX8MP to SD card, and updated all packages, then rebooted. After this, I ran reform-flash-uboot emmc as root. Uboot was downloaded and updated correctly, and a reboot afterward is successful. I reviewed the reform-flash-uboot script and it is updating the correct device and downloading the correct uboot.bin for IMX8MP Pocket Reform. So, no issues there that I can see and the process tested correctly
For the new uboot on the linked MR, I downloaded the file manually, and then ran the following:
wget https://source.mnt.re/josch/reform-imx8mp-uboot/-/jobs/6780/artifacts/raw/imx8mp-mnt-pocket-reform-flash.bin
echo 0 > /sys/class/block/mmcblk2boot0/force_ro
dd if=imx8mp-mnt-pocket-reform-flash.bin of=/dev/mmcblk2boot0
sync
reboot
After this was finished, upon reboot, I had a small hiccup which I think was related to a bad install I still haven’t properly cleaned from my Pocket Reform’s eMMC, which was partially wiped. I noted on boot that /dev/mmcblk2* was being mounted and checked, and it didn’t boot correctly. I rebooted again and the Pocket booted from the SD-card install automatically, which booted perfectly with the new uboot, no issues at all.
To make sure my dodgy eMMC install was causing the issue I experienced, I then wiped my eMMC entirely (with wipefs -a /dev/mmcblk2, skipping uboot of course, as force_ro was still set to 1 on mmcblk2boot0, preventing writes to the boot blocks) and rebooted and everything worked as expected. The Pocket Reform booted from the system image on the SD card with the new uboot on eMMC without any issues at all.
So that hiccup on first boot seems explainable as remnants of a dodgy eMMC install, and not related to the new uboot image. Just documenting this for completeness. As far as I can test, this is all working correctly too.
I do notice that on the new uboot there is a brief green flash on the screen prior to the text console appearing - it doesn’t prevent anything from working and goes away immediately, but I thought I should mention it. It’s purely a cosmetic difference I noticed. Hope this helps!
