Since I had to cross-compile the LPC firmware on Gentoo today, I wanted to share my findings, in case anyone else runs into the same issues:
- You can use Gentoo’s “crossdev” script to set up the toolchain.
- Check the page from the Gentoo Wiki for instructions how to install crossdev.
- The target needed for the LPC firmware is
arm-none-eabi
. - You’ll need gcc, so don’t use the
--llvm
flag when installing the toolchain.
- Before you can compile the actual firmware binary, you need to compile lpcrc in the
tools/lpcrc
folder.- Just change into that folder and run
make
- At the time I’m writing this (2024-02-22) the toolchain installed by crossdev has
_FORTIFY_SOURCE
defined. The LPC firmware does not compile if this feature is enabled (with rather confusing error messages).- You can disable it in the main Makefile of the LPC firmware. I added the following two lines, but I’m not certain if the second one is actually needed:
GCFLAGS += -U_FORTIFY_SOURCE GCFLAGS += -D_FORTIFY_SOURCE=0
- Since I already had parts of the project compiled before I made those changes to the makefile, I got weird linker errors. If you get errors like
undefined reference to '_exit'
, you might want to do amake clean
and try again. At least for me that fixed those.
