Hello everyone
I have a problem with the ZZ9000 card that I received this week. I contacted support but they are out of office until November 23 so I’m trying here, maybe someone can help me.
I have an AMIGA 4000 with a 68060 BFG 9060 card and some Zorro expansion cards: X-Surf 100 and Buddha IDE, also an Indivision 4000 (which I just removed for the ZZ9000).
The mainboard has been checked and recapped, the original battery did not cause any damage.
Everything works w’ell since I own the machine (about 4 years).
The problem I have is the following:
The amiga starts correctly on the workbench but after a minute the display crashes with arctifacts and the amiga reboot with a guru.
I first thought of a problem with my software installation but the problem come back under the early startup.
I also thought of an incompatibility with my BFG card and unfortunately the problem is the same with my original A3630 card.
I tried with the following configuration:
BFG 9060 + Firmware 1.12.1 no zorro ram, with or without mainbaord RAM
BFG 9060 + Firmware 1.12.1 Zorro 2 (just a desperate try)
A3630+ Firmware 1.12.1 no fast ram, with mainbaord RAM
A3630+ Firmware 1.12.1 zorro ram, with or without mainbaord RAM
The problem is desperately the same.
Does my ZZ9000 have a problem or do you think this is from my 4000?
I put you the links to two videos to illustrate:
workbench crash : Workbench crash - YouTube
Early startup crash : Early startup crash - YouTube
Thanks to everybody.
- Amiga model: A4000D
- 680x0 CPU: 68060 REV6 on BFG 9060
- RAM Configuration: 128 Mo on CPU board
- Kickstart, AmigaOS Versions: 3.2.1
- ZZ9000 Firmware version: 1.12.1 no ram
- ZZ9000 Driver version: none, can’t install it.
- Monitor model: ELO ET1723L
- Other Zorro cards: Buddha IDE and X-surf 100 with rapidroad.
