after one of my original MNT Reform batteries started acting up, I replaced all my cells with the 2000 mAh Eremit batteries and I’m not looking back. Now I have 7 nearly new JGNE 18650 1800mAh original batteries that are looking for a new owner. If you want one of them because you also find yourself with a faulty cell, just drop me a private message. I don’t want any money for the cells, just pay for the shipping and I’ll be happy to send them to you. I’m located in Germany. Thanks!
I have 8 cell as well after getting the Eremit batteries, and I am just holding onto them. I have 2 flashlights which use 18650 cells and I am kind of just saving them for those or for when the eremit’s conk out. They go through quite a bit of charge cycles just in regular use of the Reform.
That is pretty rad of your to offer your extras out like that!
I assume (I’m not an engineer update: This might be potentially dangerous. Don’t blame me if the device catches fire and everything around it burns down ) changing
// 1.8A x 3600 seconds/hour #define MAX_CAPACITY (1.8)*3600.0
to #define MAX_CAPACITY (2.0)*3600.0
in the LPC sources reform2-lpc-fw/src/boards/reform2/board_reform2.c · master · Reform / reform · GitLab will do the right estimation with the new battery capacity.
I’m also not an engineer… But I assume that any mention of changing LPC sources, especially from a non-EE background, should be accompanied by the disclaimer that doing so could be potentially dangerous (to you and your Reform). I suppose the fire risk is less real with this battery chemistry, but still there?
Thank you. I’ll update the post.
Charging is done by voltage levels. The max_capacity is used for estimation of the remaining battery power. I wouldn’t use deep discharged batteries too if there is concern of fire. The most laptop batteries (if not all) are disabled by a blown up, non resettable, security fuse when one of the cells is below the minimum voltage level (around 2V-2.5V.) Yes you are right, it might be potentially dangerous changing batteries to out of specification types .
