Here is a patch for the Pocket keyboard firmware to dim the LEDs after some period of inactivity. The LEDs return to their previous brightness/state when a key is pressed.
This is based on code that was shared in a previous thread for the Reform (I added a timeout to the (standalone) keyboard backlight)
--- a/pocket-reform-keyboard-fw/pocket-hid/src/main.c
+++ b/pocket-reform-keyboard-fw/pocket-hid/src/main.c
@@ -71,6 +71,15 @@ static uint8_t pressed_scancodes[MAX_SCANCODES] = {0,0,0,0,0,0};
static int pressed_keys = 0;
static volatile uint32_t led_value = 0;
+// used for keyboard dimming
+int idle_counter = 0;
+int saved_brightness;
+bool dimmed = false;
+int led_brightness = 0;
+int led_saturation = 255;
+int led_hue = 127;
void hid_task(void);
int process_keyboard(uint8_t* resulting_scancodes);
@@ -426,8 +435,25 @@ int process_keyboard(uint8_t* resulting_scancodes) {
// if no more keys are held down, allow a new menu command
- if (total_pressed<1) last_menu_key = 0;
+ if (total_pressed<1) {
+ last_menu_key = 0;
+ if (!dimmed) {
+ if (idle_counter >= 1000000) {
+ dimmed = true;
+ saved_brightness = led_brightness;
+ led_set_brightness(0);
+ } else {
+ idle_counter++;
+ } else {
+ if (dimmed) {
+ led_set_brightness(saved_brightness);
+ dimmed = false;
+ idle_counter = 0;
// if device is off and user is pressing random keys,
// show a hint for turning on the device
if (!remote_get_power_state()) {
@@ -659,10 +685,6 @@ void hid_task(void)
-int led_brightness = 0;
-int led_saturation = 255;
-int led_hue = 127;
typedef struct RgbColor
unsigned char r;
In addition, to turn off the screen after a period of inactivity you can add the following to .sway/config:
exec swayidle -w \
timeout 600 'swaymsg "output * dpms off"' \
resume 'swaymsg "output * dpms on"'
