Keyboard v4 not compatible with anti-flexing inserts in Reform?
Trying to install V4 keyboard in my Reform classic and the anti-flexing bars don’t seem to fit between the diodes on the bottom side of the keyboard PCB causing it to arch a bit up when screwed to the case.
Am I doing anything wrong here or is the new keyboard not compatible with the inserts?
We’re taking a look soon and will get back to you. Thanks for your patience!
Today we tested the anti-flexing bars and found that indeed some of the components on the underside of the V4 keyboard need more clearance, around 1.25mm. The bar has been redesigned and you’ll find a new STL file here. Anyone who orders the keyboard from now on will get bars that are right size. Thank you so much for the feedback!
