Low profile antenna mod
Previously, owing to poor wifi reception compared to the Thinkpad my Reform was replacing, I replaced the default MIMO antenna with a pair of 8dbi external antennas in a rabbit-ear configuration. This worked great until I had a baby. Recently he tore one of the antennas right off its wire, so I decided to switch to a different design.
The reception is not as good as it was with the ear-style mod, but it’s better than I had been getting with the default antenna in its default position. I will be quite surprised if my child manages to break this one.
OpenSCAD files and STLs for both the ears-style mod and the new low-profile mod are up on Codeberg now. Photos are below.
Hi!
I did this mod to my reform too! It’s pretty great. I haven’t noticed a huge difference to the signal strength that I see from Linux, but what I have found is that my connection is much more stable at a low signal strength.
I used 3D printed ABS for my brackets, and I think it looks pretty slick. Thanks heaps for sharing the files!
I love your color scheme! Glad to hear you’re getting use out of my mod as well. :smile:
Interesting. I really liked the rabbit ears version but your reasoning for moving beyond them makes a ton of sense. I think in my own house I have the wifi just too saturated through a mesh network, so I haven’t really seen a need to modify my wifi antenna.
However thank you for sharing and including pictures! Both of you! Pretty cool stuff indeed.
