murph
August 18, 2025, 11:49pm
21
I’m getting a more interesting error.
Parsing Found/Fixed information... Done critical bugs of systemd (257.7-1 → 258~rc2-2) <Outstanding>
b1 - #1110980 - /var/lock/ is the standard interface for serial devices locks
serious bugs of systemd (257.7-1 → 258~rc2-2) <Outstanding>
b2 - #1111141 - systemctl ends in assertion failed on armhf Summary: systemd(2 bugs) Are you sure you want to install/upgrade the above packages? [Y/n/?/...]
Any suggestions?
josch
August 18, 2025, 11:57pm
22
If you care about wayfire, please consider contributing to it to make things like this work again. The wf-config package in Debian is orphaned and there is an ongoing wlroots transition: Transition: wlroots (auto)
You can read details about these bug by going to https://bugs.debian.org/XXXXXXX and replace the XXXXXXX with the bug number. Then you can decide whether you might be affected by the issue or not.
shigeru
August 19, 2025, 12:17am
23
Hello @josch ,
Here is the result of sudo apt update and the command you indicated, then as shown I have aborted the process;
shigeru@mntpr-0:~/Downloads$ sudo apt update
Get:1 http://deb.debian.org/debian unstable InRelease [216 kB]
Ign:2 https://mntre.com/reform-debian-repo reform InRelease
Get:3 http://deb.debian.org/debian unstable/main arm64 Packages.diff/Index [63.6 kB]
Hit:4 https://mntre.com/reform-debian-repo reform Release
Get:5 http://deb.debian.org/debian unstable/main Translation-en.diff/Index [63.6 kB]
Get:6 http://deb.debian.org/debian unstable/main arm64 Contents (deb).diff/Index [63.8 kB]
Get:7 http://deb.debian.org/debian unstable/main all Contents (deb).diff/Index [63.8 kB]
Ign:8 https://mntre.com/reform-debian-repo reform Release.gpg
Hit:9 tor+http://apow7mjfryruh65chtdydfmqfpj5btws7nbocgtaovhvezgccyjazpqd.onion/torproject.org trixie InRelease
Get:10 http://deb.debian.org/debian unstable/main arm64 Packages T-2025-08-18-2009.29-F-2025-08-18-1405.39.pdiff [46.5 kB]
Get:11 http://deb.debian.org/debian unstable/main Translation-en T-2025-08-18-1405.39-F-2025-08-18-1405.39.pdiff [2,982 B]
Get:12 http://deb.debian.org/debian unstable/main arm64 Contents (deb) T-2025-08-18-2009.29-F-2025-08-18-1405.39.pdiff [6,293 B]
Get:13 http://deb.debian.org/debian unstable/main all Contents (deb) T-2025-08-18-2009.29-F-2025-08-18-1405.39.pdiff [15.5 kB]
Get:14 http://deb.debian.org/debian unstable/main arm64 Components [4,744 kB]
Fetched 5,286 kB in 38s (140 kB/s)
478 packages can be upgraded. Run 'apt list --upgradable' to see them.
Notice: Missing Signed-By in the sources.list(5) entry for 'https://mntre.com/reform-debian-repo'
shigeru@mntpr-0:~/Downloads$ sudo apt full-upgrade -oDebug::pkgProblemResolver=true -oDebug::pkgDepCache::Marker=1 -oDebug::pkgDepCache::AutoInstall=1
MarkInstall libvulkan1:arm64 < 1.4.321.0-1 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on mesa-vulkan-drivers:arm64
MarkInstall libgedit-gtksourceview-300-3:arm64 < 299.5.0-1 -> 299.5.0-2 @ii umU Ib > FU=0
Installing libxml2-16:arm64 as Depends of libgedit-gtksourceview-300-3:arm64
MarkInstall libxml2-16:arm64 < none -> 2.14.5+dfsg-0.1 @un uN > FU=0
MarkInstall libcanberra-gtk3-0:arm64 < 0.30-18 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on libcanberra-gtk3-module:arm64
MarkInstall u-boot-tools:arm64 < 2025.01-3 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on device-tree-compiler:arm64
ignore old unsatisfied important dependency on libubootenv-tool:arm64
MarkInstall libimobiledevice-1.0-6:arm64 < 1.3.0+git20250228-2 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on usbmuxd:arm64
MarkInstall iptables:arm64 < 1.8.11-2 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on nftables:arm64
MarkInstall gnome-software:arm64 < 48.3-2 -> 48.4-1 @ii umU NPb IPb > FU=0
ignore old unsatisfied important dependency on gnome-software-plugin-fwupd:arm64
ignore old unsatisfied important dependency on gnome-software-plugin-deb:arm64
MarkInstall libfluidsynth3:arm64 < 2.4.4+dfsg-1 -> 2.4.7+dfsg-2 @ii umU Ib > FU=0
Installing libsdl3-0:arm64 as Depends of libfluidsynth3:arm64
MarkInstall libsdl3-0:arm64 < none -> 3.2.20+ds-2 @un uN > FU=0
MarkInstall libxml2-dev:arm64 < 2.12.7+dfsg+really2.9.14-2.1 -> 2.14.5+dfsg-0.1 @ii umU Ib > FU=0
Installing liblzma-dev:arm64 as Depends of libxml2-dev:arm64
MarkInstall liblzma-dev:arm64 < none -> 5.8.1-1 @un uN > FU=0
MarkInstall libdecor-0-0:arm64 < 0.2.3-2 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on default-libdecor-0-plugin-1:arm64
MarkInstall libmtp9t64:arm64 < 1.1.22-1 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on libmtp-runtime:arm64
MarkInstall mpv:arm64 < 0.40.0-3 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on yt-dlp:arm64
MarkInstall libspa-0.2-libcamera:arm64 < 1.4.7-3 -> 1.4.7-3+b1 @ii umU Ib > FU=0
Installing libcamera0.5:arm64 as Depends of libspa-0.2-libcamera:arm64
MarkInstall libcamera0.5:arm64 < none -> 0.5.2-2 @un uN Ib > FU=0
Installing libpisp1:arm64 as Depends of libcamera0.5:arm64
MarkInstall libpisp1:arm64 < none -> 1.2.1-2 @un uN Ib > FU=0
Installing libpisp-common:arm64 as Depends of libpisp1:arm64
MarkInstall libpisp-common:arm64 < none -> 1.2.1-2 @un uN > FU=0
Installing libboost-log1.83.0:arm64 as Depends of libpisp1:arm64
MarkInstall libboost-log1.83.0:arm64 < none -> 1.83.0-4.2 @un uN Ib > FU=0
Installing libboost-filesystem1.83.0:arm64 as Depends of libboost-log1.83.0:arm64
MarkInstall libboost-filesystem1.83.0:arm64 < none -> 1.83.0-4.2 @un uN > FU=0
MarkInstall libheif1:arm64 < 1.19.8-1 -> 1.20.2-2 @ii umU NPb IPb > FU=0
ignore old unsatisfied important dependency on libheif-plugin-x265:arm64
ignore old unsatisfied important dependency on libheif-plugin-aomenc:arm64
MarkInstall libcap2-bin:arm64 < 1:2.75-10+b1 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on libpam-cap:arm64
MarkInstall libpsl5t64:arm64 < 0.21.2-1.1+b1 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on publicsuffix:arm64
MarkInstall libbluray2:arm64 < 1:1.3.4-1+b2 -> 1:1.3.4-1+b3 @ii umU NPb IPb > FU=0
ignore old unsatisfied important dependency on libaacs0:arm64
MarkInstall libusb-1.0-0-dev:arm64 < 2:1.0.29-2 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on libusb-1.0-doc:arm64
MarkInstall debconf:arm64 < 1.5.91 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on debconf-i18n:arm64
MarkInstall vim-common:arm64 < 2:9.1.1230-2 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on xxd:arm64
MarkInstall udisks2:arm64 < 2.10.1-12.1 -> 2.10.90-3 @ii umU NPb Ib > FU=0
Installing libblockdev-smart3:arm64 as Depends of udisks2:arm64
MarkInstall libblockdev-smart3:arm64 < none -> 3.3.1-3 @un uN > FU=0
ignore old unsatisfied important dependency on ntfs-3g:arm64
ignore old unsatisfied important dependency on exfatprogs:arm64
MarkInstall gnupg:arm64 < 2.4.8-2 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on gnupg-utils:arm64
ignore old unsatisfied important dependency on gpg-wks-client:arm64
MarkInstall libvdpau1:arm64 < 1.5-3+b1 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on vdpau-driver-all:arm64
MarkInstall systemd:arm64 < 257.7-1 -> 258~rc2-2 @ii umU NPb IPb > FU=0
ignore old unsatisfied important dependency on systemd-cryptsetup:arm64
MarkInstall libgpg-error0:arm64 < 1.55-2 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on libgpg-error-l10n:arm64
MarkInstall libcamera0.4:arm64 < 0.4.0-7 @ii mK IPb > FU=0
previously satisfied important dependency on libcamera-ipa:arm64
libcamera0.4:arm64 Recommends on libcamera-ipa:arm64 < 0.4.0-7 -> 0.5.2-2 @ii umU > (= 0.4.0-7) can't be satisfied! (dep)
MarkInstall libqt5gui5t64:arm64 < 5.15.15+dfsg-6 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on qt5-gtk-platformtheme:arm64
MarkInstall lvm2:arm64 < 2.03.31-2 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on thin-provisioning-tools:arm64
MarkInstall dpkg-dev:arm64 < 1.22.21 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on fakeroot:arm64
ignore old unsatisfied important dependency on libalgorithm-merge-perl:arm64
MarkInstall libaspell15:arm64 < 0.60.8.1-4 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on aspell-en:arm64
MarkInstall libkrb5-3:arm64 < 1.21.3-5 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on krb5-locales:arm64
MarkInstall gnome-settings-daemon:arm64 < 48.1-1 -> 48.1-2 @ii umU IPb > FU=0
new important dependency: systemd-oomd:arm64
Installing systemd-oomd:arm64 as Recommends of gnome-settings-daemon:arm64
MarkInstall systemd-oomd:arm64 < none -> 258~rc2-2 @un uN > FU=0
MarkInstall minetest-mod-moreblocks:arm64 < 2.2.0-2 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on minetest-mod-intllib:arm64
MarkInstall xserver-common:arm64 < 2:21.1.16-1.3 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on xfonts-base:arm64
MarkInstall isc-dhcp-client:arm64 < 4.4.3-P1-8 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on isc-dhcp-common:arm64
MarkInstall network-manager:arm64 < 1.54.0-3 -> 1.54.0-4 @ii umU NPb IPb > FU=0
ignore old unsatisfied important dependency on dnsmasq-base:arm64
MarkInstall libgphoto2-6t64:arm64 < 2.5.31-4 -> 2.5.31-4+b2 @ii umU NPb IPb > FU=0
ignore old unsatisfied important dependency on libgphoto2-l10n:arm64
MarkInstall libpocketsphinx3:arm64 < 0.8+5prealpha+1-15+b4 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on pocketsphinx-en-us:arm64
MarkInstall firmware-misc-nonfree:arm64 < 20250410-2 -> 20250808-1 @ii umU NPb IPb > FU=0
ignore old unsatisfied important dependency on firmware-nvidia-graphics:arm64
ignore old unsatisfied important dependency on firmware-intel-graphics:arm64
ignore old unsatisfied important dependency on firmware-intel-misc:arm64
MarkInstall rsyslog-mongodb:arm64 < 8.2506.0-2 -> 8.2506.0-3 @ii umU NPb Ib > FU=0
Installing libbson2-2:arm64 as Depends of rsyslog-mongodb:arm64
MarkInstall libbson2-2:arm64 < none -> 2.1.0-1 @un uN > FU=0
Installing libmongoc2-2:arm64 as Depends of rsyslog-mongodb:arm64
MarkInstall libmongoc2-2:arm64 < none -> 2.1.0-1 @un uN > FU=0
ignore old unsatisfied important dependency on mongodb-server:arm64
MarkInstall libasound2-data:arm64 < 1.2.14-1 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on alsa-topology-conf:arm64
MarkInstall libdpkg-perl:arm64 < 1.22.21 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on libfile-fcntllock-perl:arm64
MarkInstall thunar:arm64 < 4.20.4-1 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on thunar-volman:arm64
ignore old unsatisfied important dependency on libxfce4panel-2.0-4:arm64
MarkInstall libxfce4util7:arm64 < 4.20.1-1 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on libxfce4util-bin:arm64
MarkInstall libgpgme11t64:arm64 < 1.24.2-3 @ii mK NPb IPb > FU=0
MarkInstall libgtk-4-1:arm64 < 4.18.6+ds-2 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on libgtk-4-bin:arm64
MarkInstall sway:arm64 < 1.10.1-2 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on wmenu:arm64
MarkInstall reform-firedecor:arm64 < 2023-10-23-8 @ii mK Ib > FU=0
reform-firedecor:arm64 Depends on libwf-config1:arm64 < 0.9.0-2 -> 0.9.0-2+b1 @ii umU > (= 0.9.0-2) can't be satisfied! (dep)
MarkInstall libpipewire-0.3-0t64:arm64 < 1.4.7-3 -> 1.4.7-3+b1 @ii umU NPb IPb > FU=0
ignore old unsatisfied important dependency on libpipewire-0.3-common:arm64
MarkInstall console-data:arm64 < 2:1.12-9 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on console-common:arm64
MarkInstall apt-listbugs:arm64 < 0.1.47 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on ruby-httpclient:arm64
MarkInstall xdg-utils:arm64 < 1.2.1-2 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on libfile-mimeinfo-perl:arm64
ignore old unsatisfied important dependency on libnet-dbus-perl:arm64
ignore old unsatisfied important dependency on libx11-protocol-perl:arm64
MarkInstall systemd-sysv:arm64 < 257.7-1 -> 258~rc2-2 @ii umU NPb IPb > FU=0
ignore old unsatisfied important dependency on libnss-systemd:arm64
MarkInstall cron:arm64 < 3.0pl1-197 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on default-mta:arm64
MarkInstall libenchant-2-2:arm64 < 2.8.2+dfsg1-3 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on enchant-2:arm64
MarkInstall libpskc0t64:arm64 < 2.6.13-2 -> 2.6.13-2+b1 @ii umU Ib > FU=0
Installing libxmlsec1-1:arm64 as Depends of libpskc0t64:arm64
Delayed Removing: libxmlsec1t64:arm64 as upgrade is not an option for libxmlsec1-1:arm64 (1.3.7-2)
MarkInstall libxmlsec1-1:arm64 < none -> 1.3.7-2 @un uN Ib > FU=0
MarkDelete libxmlsec1t64:arm64 < 1.2.41-1+b1 @ii mK > FU=0
Installing libxmlsec1-openssl1:arm64 as Depends of libpskc0t64:arm64
Delayed Removing: libxmlsec1t64-openssl:arm64 as upgrade is not an option for libxmlsec1-openssl1:arm64 (1.3.7-2)
MarkInstall libxmlsec1-openssl1:arm64 < none -> 1.3.7-2 @un uN Ib > FU=0
MarkDelete libxmlsec1t64-openssl:arm64 < 1.2.41-1+b1 @ii mK Ib > FU=0
MarkInstall libthunarx-3-0:arm64 < 4.20.4-1 @ii mK NPb IPb > FU=0
MarkInstall libgtk-3-0t64:arm64 < 3.24.50-1 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on libgtk-3-bin:arm64
MarkInstall fonts-droid-fallback:arm64 < 1:8.1.0r7-1~1.gbp36536b @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on fonts-noto-mono:arm64
MarkInstall libva2:arm64 < 2.22.0-3 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on va-driver-all:arm64
MarkInstall dkms:arm64 < 3.2.0-1 @ii mK NPb IPb > FU=0
MarkInstall libqt5core5t64:arm64 < 5.15.15+dfsg-6 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on qttranslations5-l10n:arm64
MarkInstall e2fsprogs:arm64 < 1.47.2-3+b3 @ii mK NPb IPb > FU=0
ignore old unsatisfied important dependency on e2fsprogs-l10n:arm64
MarkKeep libxmlsec1t64:arm64 < 1.2.41-1+b1 @ii mR > FU=0
MarkKeep libxmlsec1t64-openssl:arm64 < 1.2.41-1+b1 @ii mR > FU=0
Starting pkgProblemResolver with broken count: 3
Starting 2 pkgProblemResolver with broken count: 3
Investigating (0) libxmlsec1-1:arm64 < none -> 1.3.7-2 @un uN Ib >
Broken libxmlsec1-1:arm64 Conflicts on libxmlsec1:arm64 < none @un H >
Considering libxmlsec1t64:arm64 11 as a solution to libxmlsec1-1:arm64 2
MarkKeep libxmlsec1-1:arm64 < none -> 1.3.7-2 @un uN Ib > FU=0
Holding Back libxmlsec1-1:arm64 rather than change libxmlsec1:arm64
Investigating (0) libxmlsec1-openssl1:arm64 < none -> 1.3.7-2 @un uN Ib >
Broken libxmlsec1-openssl1:arm64 Depends on libxmlsec1-1:arm64 < none | 1.3.7-2 @un uH > (>= 1.3.0)
Considering libxmlsec1-1:arm64 2 as a solution to libxmlsec1-openssl1:arm64 1
MarkKeep libxmlsec1-openssl1:arm64 < none -> 1.3.7-2 @un uN Ib > FU=0
Holding Back libxmlsec1-openssl1:arm64 rather than change libxmlsec1-1:arm64
Investigating (0) reform-firedecor:arm64 < 2023-10-23-8 @ii mK Ib >
Broken reform-firedecor:arm64 Depends on libwf-config1:arm64 < 0.9.0-2 -> 0.9.0-2+b1 @ii umU > (= 0.9.0-2)
Considering libwf-config1:arm64 1 as a solution to reform-firedecor:arm64 0
Removing reform-firedecor:arm64 rather than change libwf-config1:arm64
MarkDelete reform-firedecor:arm64 < 2023-10-23-8 @ii mK Ib > FU=0
Investigating (1) libpskc0t64:arm64 < 2.6.13-2 -> 2.6.13-2+b1 @ii umU Ib >
Broken libpskc0t64:arm64 Depends on libxmlsec1-1:arm64 < none | 1.3.7-2 @un uH > (>= 1.2.31)
Considering libxmlsec1-1:arm64 2 as a solution to libpskc0t64:arm64 4
MarkKeep libpskc0t64:arm64 < 2.6.13-2 -> 2.6.13-2+b1 @ii umU Ib > FU=0
Holding Back libpskc0t64:arm64 rather than change libxmlsec1-1:arm64
Try to Re-Instate (2) libpskc0t64:arm64
Done
Entering ResolveByKeep
argyll argyll-ref libcamera0.4 libmongoc-1.0-0t64
Upgrading:
apache2 libjavascriptcoregtk-4.1-0
apache2-bin libjavascriptcoregtk-6.0-1
apache2-suexec-pristine libkf6doctools6
apache2-utils libkf6kiocore6
appstream libkf6kiogui6
bind9-dnsutils libkpathsea6
bind9-host libkpim6akonadicore6
bind9-libs libkpim6akonadiprivate6
binutils libkpim6akonadiwidgets6
binutils-aarch64-linux-gnu liblangtag1
binutils-common liblibreoffice-java
clang-19 liblibreofficekitgtk
clang-tools-19 libllvm19
coinor-libcoinutils3v5 liblrdf0
coinor-libosi1v5 libmagickcore-7.q16-10
cryptsetup libmagickcore-7.q16-10-extra
cryptsetup-bin libmagickwand-7.q16-10
cryptsetup-initramfs libmanette-0.2-0
desktop-base libmariadb3
dracut-install libmspub-0.1-1
evince libneon27t64
evince-common libnetpbm11t64
evolution libnfsidmap1
evolution-common libnghttp2-14
evolution-data-server libnm0
evolution-data-server-common libnma-common
evolution-ews libnma-gtk4-0
evolution-ews-core libnma0
evolution-plugin-bogofilter libnss-myhostname
evolution-plugin-pstimport libodfgen-0.1-1
evolution-plugins libopenal-data
evolution-plugins-experimental libopenal1
ffmpeg libopenconnect5
firmware-amd-graphics libosinfo-1.0-0
firmware-atheros libosinfo-l10n
firmware-iwlwifi libostree-1-1
firmware-mediatek libpam-gnome-keyring
firmware-misc-nonfree libpam-systemd
firmware-realtek libpeas-1.0-0
flatpak libpeas-common
fonts-opensymbol libpipewire-0.3-0t64
foot libpipewire-0.3-modules
fuse3 libpostproc58
gcr4 libppsdocument-4.0-5
gdm3 libppsview-4.0-4
gettext libpq5
gettext-base libpurple0t64
gir1.2-evince-3.0 libraptor2-0
gir1.2-gck-2 librelp0
gir1.2-gcr-4 libreoffice-base-core
gir1.2-gdesktopenums-3.0 libreoffice-calc
gir1.2-gdkpixbuf-2.0 libreoffice-common
gir1.2-gdm-1.0 libreoffice-core
gir1.2-glib-2.0 libreoffice-draw
gir1.2-gnomebg-4.0 libreoffice-gnome
gir1.2-gnomedesktop-4.0 libreoffice-gtk3
gir1.2-goa-1.0 libreoffice-help-common
gir1.2-grilo-0.3 libreoffice-help-en-us
gir1.2-gst-plugins-bad-1.0 libreoffice-impress
gir1.2-gtklayershell-0.1 libreoffice-java-common
gir1.2-gtksource-300 libreoffice-math
gir1.2-gtksource-4 libreoffice-style-colibre
gir1.2-gweather-4.0 libreoffice-style-elementary
gir1.2-handy-1 libreoffice-uiconfig-calc
gir1.2-javascriptcoregtk-4.1 libreoffice-uiconfig-common
gir1.2-lokdocview-0.1 libreoffice-uiconfig-draw
gir1.2-nm-1.0 libreoffice-uiconfig-impress
gir1.2-nma4-1.0 libreoffice-uiconfig-math
gir1.2-peas-1.0 libreoffice-uiconfig-writer
gir1.2-rb-3.0 libreoffice-writer
gir1.2-rest-1.0 libreofficekit-data
gir1.2-rsvg-2.0 librest-1.0-0
gir1.2-shumate-1.0 librhythmbox-core10
gir1.2-telepathylogger-0.2 librsvg2-2
gir1.2-totem-1.0 librsvg2-common
gir1.2-totemplparser-1.0 librtmp1
gir1.2-tracker-3.0 librygel-core-2.8-0
gir1.2-upowerglib-1.0 librygel-db-2.8-0
gir1.2-webkit2-4.1 librygel-renderer-2.8-0
glycin-loaders librygel-renderer-gst-2.8-0
gnome librygel-ruih-2.8-0
gnome-backgrounds librygel-server-2.8-0
gnome-calculator libsane1
gnome-connections libsframe2
gnome-control-center libsgutils2-1.48
gnome-core libshumate-1.0-1
gnome-desktop3-data libshumate-common
gnome-keyring libspa-0.2-bluetooth
gnome-keyring-pkcs11 libspa-0.2-libcamera
gnome-maps libspa-0.2-modules
gnome-online-accounts libstoken1t64
gnome-settings-daemon libsuitesparseconfig7
gnome-settings-daemon-common libswresample5
gnome-software libswscale8
gnome-software-common libsynctex2
gnome-software-plugin-flatpak libsystemd-shared
gnome-user-share libsystemd0
gnuplot libtelepathy-logger3
gnuplot-data libtinysparql-3.0-0
gnuplot-qt libtotem-plparser18
gnustep-base-runtime libtotem0
gpiod libudev1
grilo-plugins-0.3 libudisks2-0
gsettings-desktop-schemas libumfpack6
gstreamer1.0-gtk3 libuno-cppu3t64
gstreamer1.0-libcamera libuno-cppuhelpergcc3-3t64
gstreamer1.0-pipewire libuno-purpenvhelpergcc3-3t64
gstreamer1.0-plugins-bad libuno-sal3t64
gstreamer1.0-plugins-good libuno-salhelpergcc3-3t64
gvfs libunoloader-java
gvfs-backends libupower-glib3
gvfs-daemons libvisio-0.1-1
gvfs-fuse libvlc-bin
gvfs-libs libvlc5
heif-gdk-pixbuf libvlccore9
heif-thumbnailer libvolume-key1
imagemagick libwayland-client0
imagemagick-7.q16 libwayland-cursor0
init-system-helpers libwayland-egl1
initramfs-tools libwayland-server0
initramfs-tools-bin libwebkit2gtk-4.1-0
initramfs-tools-core libwebkitgtk-6.0-4
kio6 libwf-config1
libabw-0.1-1 libwildmidi2
libamd3 libxkbcommon-x11-0
libapache2-mod-php8.4 libxkbcommon0
libappstream5 libxkbregistry0
libarchive13t64 libxml++2.6-2v5
libasprintf-dev libxml-libxml-perl
libasprintf0v5 libxml2
libatasmart4 libxml2-dev
libatk-wrapper-java libxslt1.1
libatk-wrapper-java-jni libxvidcore4
libavcodec61 libyelp0
libavdevice61 libyuv0
libavfilter10 libzbar0t64
libavformat61 libzimg2
libavutil59 lld-19
libbinutils llvm-19
libblockdev-crypto3 llvm-19-dev
libblockdev-fs3 llvm-19-linker-tools
libblockdev-loop3 llvm-19-runtime
libblockdev-mdraid3 llvm-19-tools
libblockdev-nvme3 mariadb-common
libblockdev-part3 memcached
libblockdev-swap3 netpbm
libblockdev-utils3 network-manager
libblockdev3 network-manager-applet
libbluray2 network-manager-gnome
libbpf1 network-manager-l10n
libbrasero-media3-1 network-manager-openvpn
libbytesize-common network-manager-openvpn-gnome
libbytesize1 network-manager-pptp
libcaja-extension1 network-manager-pptp-gnome
libcamd3 network-manager-vpnc
libcamel-1.2-64t64 network-manager-vpnc-gnome
libcamera-ipa nginx
libccolamd3 nm-connection-editor
libcholmod5 openconnect
libclang-common-19-dev papers
libclang-cpp19 papers-common
libclang-rt-19-dev php8.4-cli
libclang1-19 php8.4-common
libcmis-0.6-6t64 php8.4-fpm
libcolamd3 php8.4-opcache
libcryptsetup12 php8.4-readline
libctf-nobfd0 pipewire
libctf0 pipewire-alsa
libe-book-0.1-1 pipewire-bin
libebackend-1.2-11t64 pipewire-pulse
libebook-1.2-21t64 python-sqlalchemy-doc
libebook-contacts-1.2-4t64 python-zstandard-doc
libecal-2.0-3 python3-beaker
libedata-book-1.2-27t64 python3-blinker
libedata-cal-2.0-2t64 python3-requests
libedataserver-1.2-27t64 python3-scriptforge
libedataserverui-1.2-4t64 python3-sqlalchemy
libedataserverui4-1.0-0t64 python3-sqlalchemy-ext
libetonyek-0.1-1 python3-typeguard
libevdocument3-4t64 python3-uno
libevolution python3-urllib3
libevview3-3t64 python3-zstandard
libflashrom1 rhythmbox
libflatpak0 rhythmbox-plugin-cdrecorder
libfluidsynth3 rhythmbox-plugins
libfuse3-4 rsyslog
libgck-2-2 rsyslog-clickhouse
libgcr-4-4 rsyslog-doc
libgdk-pixbuf-2.0-0 rsyslog-docker
libgdk-pixbuf2.0-bin rsyslog-elasticsearch
libgdk-pixbuf2.0-common rsyslog-gssapi
libgdm1 rsyslog-hiredis
libgedit-gtksourceview-300-3 rsyslog-kafka
libgedit-gtksourceview-300-common rsyslog-kubernetes
libges-1.0-0 rsyslog-mongodb
libgettextpo-dev rsyslog-relp
libgettextpo0 rsyslog-snmp
libgexiv2-2 rygel
libgit2-1.9 rygel-playbin
libglib2.0-0t64 rygel-preferences
libglib2.0-bin rygel-ruih
libglib2.0-data rygel-tracker
libgnome-bg-4-2t64 sane-airscan
libgnome-desktop-3-20t64 sane-utils
libgnome-desktop-4-2t64 shared-mime-info
libgnome-rr-4-2t64 shotwell
libgnustep-base1.31 shotwell-common
libgoa-1.0-0b sudo
libgoa-backend-1.0-2 systemd
libgphoto2-6t64 systemd-sysv
libgphoto2-port12t64 tinysparql
libgpiod3 totem
libgpod-common totem-common
libgpod4t64 totem-plugins
libgprofng0 totem-video-thumbnailer
libgraphite2-3 tzdata
libgrilo-0.3-0 tzdata-legacy
libgsf-1-114 udev
libgsf-bin udisks2
libgssdp-1.6-0 uno-libs-private
libgstreamer-plugins-bad1.0-0 upower
libgtk-layer-shell0 ure
libgtksourceview-4-0 ure-java
libgtksourceview-4-common vlc
libgtksourceview-5-0 vlc-bin
libgupnp-1.6-0 vlc-plugin-access-extra
libgupnp-av-1.0-3 vlc-plugin-base
libgupnp-dlna-2.0-4 vlc-plugin-notify
libgweather-4-0t64 vlc-plugin-qt
libhandy-1-0 vlc-plugin-samba
libheif-plugin-dav1d vlc-plugin-skins2
libheif-plugin-libde265 vlc-plugin-video-output
libheif1 vlc-plugin-video-splitter
libidn12 vlc-plugin-visualization
libidn2-0 yelp
libimage-magick-q16-perl yelp-xsl
libio-socket-ssl-perl zenity
libiptcdata0 zenity-common
libjack-jackd2-0
Installing dependencies:
libblockdev-smart3 libbson2-2 libmongoc2-2 libsdl3-0
libboost-filesystem1.83.0 libcamera0.5 libpisp-common libxml2-16
libboost-log1.83.0 liblzma-dev libpisp1 systemd-oomd
Suggested packages:
liblzma-doc liburing2
Not upgrading:
libpskc0t64
REMOVING:
reform-firedecor
Summary:
Upgrading: 477, Installing: 12, Removing: 1, Not Upgrading: 1
Download size: 530 MB / 561 MB
Space needed: 32.3 MB / 733 GB available
Continue? [Y/n] n
Abort.
Hope these give you an idea. Thank you.
murph
August 19, 2025, 12:22am
24
Thanks, that’s great so I can read about the specific issue. Learning new things all the time.
josch
August 19, 2025, 12:31am
25
But you have removed the tor packages, no? Because what you pasted there looks fine. Only reform-firedecor gets removed.
shigeru
August 19, 2025, 12:54am
26
Hello @josch ,
No, I have not removed anything. TOR is still on the system, also.
Okay, I will move forward with update/full-upgrade.
Thank you for checking.
josch
August 19, 2025, 6:56am
27
But you switched the tor sources from trixie to forky?
Maybe they just did a rebuild against the updated package versions.
Hello @josch ,
Actually, I have left source Suites for TOR as trixie. When I try with forky, it complains with 404 error saying no such Release file. So I have put it back to trixie.
Maybe, they did change something while we are troubleshooting. I have proceeded with full-upgrade but set #1110980 and #1111141 for dodging. Then rebooted fine.
Hmm… It seems that apt has a problem with handling /etc/apt/preferences.d/apt-listbugs? While I have /etc/apt/preferences.d/apt-listbugs with this content:
shigeru@mntpr-0:~$ cat /etc/apt/preferences.d/apt-listbugs
Explanation: Pinned by apt-listbugs at 2025-08-19 02:59:09 -0400
Explanation: Pinning requested by shigeru (1000) during command: apt full-upgrade
Explanation: #1110980: /var/lock/ is the standard interface for serial devices locks
Explanation: #1111141: systemctl ends in assertion failed on armhf
Package: systemd
Pin: version 257.7-1
Pin-Priority: 30000
sudo apt full-upgrade returns:
shigeru@mntpr-0:~$ sudo apt full-upgrade
acl libkf6notifications6
akonadi-mime-data libkf6runner6
argyll libkf6service-bin
argyll-ref libkf6service-data
bluez-obexd libkf6service6
brasero-common libkf6solid-data
breeze-icon-theme libkf6solid6
cdrdao libkf6statusnotifieritem-data
colord-data libkf6statusnotifieritem6
cpp-14-for-host libkf6wallet-data
devio libkf6wallet6
dracut-install libkf6walletbackend6
eject libkirigami6
gcc-14-for-host libkirigamidelegates6
gir1.2-accountsservice-1.0 libkirigamidialogs6
gir1.2-evince-3.0 libkirigamilayouts6
gir1.2-gck-2 libkirigamiprimitives6
gir1.2-gcr-4 libkirigamiprivate6
gir1.2-gdm-1.0 libkleo-data
gir1.2-gnomebg-4.0 libklibc
gir1.2-gnomebluetooth-3.0 libkmailtransport-data
gir1.2-goa-1.0 libkmime-data
gir1.2-grilo-0.3 libkpim6akonadicore6
gir1.2-gtksource-4 libkpim6akonadiprivate6
gir1.2-gudev-1.0 libkpim6akonadiwidgets6
gir1.2-ibus-1.0 libkpim6identitymanagementcore6
gir1.2-javascriptcoregtk-4.1 libkpim6libkleo6
gir1.2-malcontent-0 libkpim6mailtransport6
gir1.2-mediaart-2.0 libkpim6mbox6
gir1.2-mutter-16 libkpim6mime6
gir1.2-nm-1.0 libkpim6mimetreeparsercore6
gir1.2-nma4-1.0 libkpim6mimetreeparserwidgets6
gir1.2-rb-3.0 libmalcontent-ui-1-1
gir1.2-rsvg-2.0 libmbim-utils
gir1.2-upowerglib-1.0 libmimetreeparser-data
gir1.2-webkit2-4.1 libmongoc-1.0-0t64
gnome-bluetooth-3-common libmsgraph-1-1
gnome-control-center-data libmutter-16-0
gnome-online-accounts libnss-myhostname
gnome-session-common libparted-fs-resize0t64
gnome-settings-daemon-common libpciaccess0
gnome-shell-common libplasmaactivities6
gparted-common libplymouth5
gvfs-common libpskc0t64
gvfs-libs libqca-qt6-2
ibus libqca-qt6-plugins
ibus-data libqgpgmeqt6-15
ibus-gtk libqmi-utils
ibus-gtk3 libqt6core5compat6
ibus-gtk4 libqt6keychain1
im-config libqt6quickshapes6
initramfs-tools-bin librhythmbox-core10
kded6 libsane-common
kf6-breeze-icon-theme libstoken1t64
klibc-utils libtomcrypt1
kwallet6 libtommath1
libakonadi-data libudisks2-0
libatasmart4 libvolume-key1
libblockdev-crypto3 libvpx9
libblockdev-fs3 libxmlsec1t64-openssl
libblockdev-loop3 linux-base
libblockdev-mdraid3 linux-headers-6.15.4-common
libblockdev-nvme3 linux-headers-6.15.6-common
libblockdev-part3 linux-kbuild-6.15.4
libblockdev-smart3 linux-kbuild-6.15.6
libblockdev-swap3 lxsession-data
libblockdev-utils3 mobile-broadband-provider-info
libblockdev3 modem-manager-gui-help
libbrasero-media3-1 mtd-utils
libburn4t64 mutter-common
libbytesize-common mutter-common-bin
libbytesize1 nautilus-data
libccid paperkey
libcolord-gtk4-1t64 plasma-activities-bin
libcolorhug2 power-profiles-daemon
libdrm-nouveau2 python-apt-common
libdrm-radeon1 python3-apt
libei1 python3-asn1crypto
libeis1 python3-blinker
libfprint-2-2 python3-httplib2
libfreerdp-server3-3 python3-ibus-1.0
libgdm1 python3-jwt
libgnome-bg-4-2t64 python3-lazr.restfulclient
libgnome-bluetooth-3.0-13 python3-lazr.uri
libgnome-bluetooth-ui-3.0-13 python3-mechanize
libgnome-rr-4-2t64 python3-netifaces
libgoa-backend-1.0-2 python3-oauthlib
libgsound0t64 python3-pyparsing
libgtksourceview-4-0 python3-software-properties
libgtksourceview-4-common python3-wadllib
libgtkspell3-3-0 qml6-module-org-kde-kirigami
libgusb2 qml6-module-qtqml
libieee1284-3t64 qml6-module-qtqml-models
libiniparser4 qml6-module-qtqml-workerscript
libisofs6t64 qml6-module-qtquick
libjim0.83 qml6-module-qtquick-controls
libjte2 qml6-module-qtquick-layouts
libkf6auth-data qml6-module-qtquick-shapes
libkf6calendarcore6 qml6-module-qtquick-templates
libkf6completion-data qml6-module-qtquick-window
libkf6completion6 realmd
libkf6crash6 rhythmbox-data
libkf6dbusaddons-bin sane-airscan
libkf6dbusaddons-data switcheroo-control
libkf6dbusaddons6 usb-modeswitch
libkf6doctools6 usb-modeswitch-data
libkf6itemmodels6 user-session-migration
libkf6jobwidgets-data xcvt
libkf6jobwidgets6 xdg-user-dirs-gtk
libkf6notifications-data xserver-xorg-legacy
Upgrading:
chromium imagemagick-7-doc libsybdb5
chromium-common imagemagick-7.q16 libudev1
chromium-driver libdecor-0-0 libwf-config1
chromium-sandbox libimage-magick-perl libzxcvbn0
chromium-shell libimage-magick-q16-perl perlmagick
freetds-common libmagickcore-7.q16-10 swaylock
imagemagick libmagickcore-7.q16-10-extra
imagemagick-7-common libmagickwand-7.q16-10
dbus-x11
Not upgrading:
libpskc0t64 libsystemd-shared libsystemd0 systemd-sysv
REMOVING:
blueman
bluez
colord
dbus-user-session
fbset
flash-kernel
fprintd
gdm3
gnome
gnome-bluetooth-sendto
gnome-browser-connector
gnome-color-manager
gnome-core
gnome-disk-utility
gnome-initial-setup
gnome-music
gnome-remote-desktop
gnome-session
gnome-session-bin
gnome-session-xsession
gnome-shell
gnome-shell-extension-dashtodock
gnome-shell-extension-manager
gnome-shell-extension-prefs
gnome-sushi
gnome-tweaks
gparted
gstreamer1.0-packagekit
gvfs
gvfs-backends
gvfs-daemons
gvfs-fuse
initramfs-tools
kactivitymanagerd
kio6
kleopatra
libkf6authcore6
libkf6kiocore6
libkf6kiogui6
libkpim6akonadimime6
libopenconnect5
libpam-fprintd
libpam-systemd
libpolkit-qt6-1-1
libsane1
libtss2-esys-3.0.2-0t64
libtss2-mu-4.0.1-0t64
libtss2-rc0t64
libtss2-sys1t64
libtss2-tcti-cmd0t64
libtss2-tcti-device0t64
libtss2-tcti-libtpms0t64
libtss2-tcti-mssim0t64
libtss2-tcti-spi-helper0t64
libtss2-tcti-swtpm0t64
libtss2-tctildr0t64
linux-headers-6.15.4-mnt-reform-arm64
linux-headers-6.15.6-mnt-reform-arm64
linux-headers-mnt-reform-arm64
linux-image-6.15.3-mnt-reform-arm64
linux-image-6.15.4-mnt-reform-arm64
linux-image-6.15.6-mnt-reform-arm64
linux-image-mnt-reform-arm64
lxpolkit
malcontent
malcontent-gui
media-player-info
modem-manager-gui
modemmanager
nautilus
network-manager-openconnect
network-manager-openconnect-gnome
openconnect
packagekit
packagekit-tools
pcscd
php-fpm
php8.4-fpm
pkexec
plymouth
plymouth-label
plymouth-themes
polkitd
reform-desktop-full
reform-desktop-minimal
reform-firedecor
reform-qcacld2
reform-qcacld2-6.15.3-mnt-reform-arm64
reform-qcacld2-6.15.6-mnt-reform-arm64
rhythmbox
rhythmbox-plugins
rtkit
sane-utils
simple-scan
software-properties-common
systemsettings
tpm-udev
udev
udisks2
upower
xdg-desktop-portal-gnome
xserver-xorg
xserver-xorg-core
xserver-xorg-input-all
xserver-xorg-input-libinput
xserver-xorg-input-wacom
xserver-xorg-video-all
xserver-xorg-video-amdgpu
xserver-xorg-video-ati
xserver-xorg-video-fbdev
xserver-xorg-video-mach64
xserver-xorg-video-nouveau
xserver-xorg-video-r128
xserver-xorg-video-radeon
Summary:
Upgrading: 22, Installing: 1, Removing: 122, Not Upgrading: 4
Download size: 167 MB / 167 MB
Freed space: 724 MB
Continue? [Y/n] n
Abort.
But when I move /etc/apt/preferences.d/apt-listbugs file somewhere else, sudo apt full-upgrade returns:
shigeru@mntpr-0:~$ sudo mv /etc/apt/preferences.d/apt-listbugs /tmp/
argyll argyll-ref libmongoc-1.0-0t64 libvpx9
Upgrading:
chromium libdecor-0-0 libudev1
chromium-common libimage-magick-perl libwf-config1
chromium-driver libimage-magick-q16-perl libzxcvbn0
chromium-sandbox libmagickcore-7.q16-10 perlmagick
chromium-shell libmagickcore-7.q16-10-extra swaylock
freetds-common libmagickwand-7.q16-10 systemd
imagemagick libpam-systemd systemd-sysv
imagemagick-7-common libsybdb5 udev
imagemagick-7-doc libsystemd-shared
imagemagick-7.q16 libsystemd0
Not upgrading:
libpskc0t64
REMOVING:
reform-firedecor
Summary:
Upgrading: 28, Installing: 0, Removing: 1, Not Upgrading: 1
Download size: 167 MB / 175 MB
Space needed: 1,238 kB / 732 GB available
Continue? [Y/n] n
Abort.
So is this a bug on apt? I can reproduce this behavioral difference back and forth as I move the apt-listbugs file in-and-out of /etc/apt/preferences.d/ path.
josch
August 20, 2025, 3:48pm
29
Ooooh this explains the situation perfectly, including why I am unable to reproduce this. It is not your tor mirror. What you see happens because you told apt to do two things:
keep systemd at version 257.7-1
upgrade everything
With those constraints, the only way apt found to satisfy both was to uninstall a lot of stuff because the stuff it otherwise would upgrade was incompatible with keeping systemd at version 257.7-1.
After removing the constraint of keeping systemd at version 257.7-1 you can see that one of the things that apt wants to do is upgrade it. Without upgrading it, you cannot upgrade other packages.
So no, this is not a bug in apt but a result of what you tell apt with the contents of your /etc/apt/preferences.d/apt-listbugs.
Maybe investigate whether the bugs for which you installed the pinnings are still relevant and if not, remove the pinning and then you can upgrade while only removing reform-firedecor.
Hello @josch ,
Thank you for explaining out the situation.
Just to confirm a few things, for #1111141 armhf is for 32bit ARM cpu and not for my Pocket Reform with Debian unstable, right? For #1110980 , the word “critical” scared me, but reading into the report, it seems not relevant to my case.
Thank you.
rwa
August 20, 2025, 4:21pm
31
Yes, we are using ARM64 aka aarch64.
This article is a useful explanation for people like me that are not that familiar with all the ARM stuff:
https://www.baeldung.com/linux/arm64-armel-armhf-overview
josch
August 20, 2025, 8:22pm
32
Yes.
shigeru:
Yes. If I were the maintainer, I would lower the severity but alas it technically is maybe a policy bug…
I would go ahead and do the upgrade which removes reform-firedecor after disabling the apt-listbug pinning.
Hello @josch ,
I went ahead and got this stage at the moment;
shigeru@mntpr-0:~$ sudo reform-check
I: `uname -a` output: Linux mntpr-0 6.15.6-mnt-reform-arm64 #1 SMP Debian 6.15.6-1~exp1+reform20250719T140750Z (2025-07-19) aarch64 GNU/Linux
I: Version of linux-image-mnt-reform-arm64: 6.15.6-1~exp1+reform20250719T140750Z
I: Version of reform-tools: 1.76-1+reform20250622T103710Z+1
E: Your /etc/skel/.profile contains an outdated line that attempts to print /etc/reform-help or run reform-help.
E: Consider simply deleting that offending last line of your /etc/skel/.profile.
Not upgrading:
libpskc0t64
Summary:
Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 1
Thank you.
By the way, I am wondering why those four packages are not removed with full-upgrade. Should I go ahead and do autoremove? I assume that there is some reasons why upgrading of libpskc0t64 is postponed.
josch
August 21, 2025, 6:26am
34
Because full-upgrade does not autoremove those packages which only were implicitly installed before as you might want to keep them.
If you need none of them you can go ahead and autoremove them. If you need some of them, explicitly apt install it to exclude it from auto removal.
There were some recent uploads of the package, so maybe something is borked?
Sorry for my terse replies, i’m currently in a night train from paris to spain.
murph
August 22, 2025, 2:33am
35
I’m actually not that thrilled with it, I thought it was the recommended for the pocket. Have others moved to sway and/or gnome?
josch
August 22, 2025, 9:55am
36
Yes. Minute worked on making wayfire fit for the Pocket (and we have reform-firedecor as a result of that work) because back in the day, Gnome was not working well on the Pocket. Today it does and thus the reform-setup-wizard and the reform system images no longer offer sway and wayfire but switched to suggesting sway and gnome. I’m still on sway. I’d give gnome to people unfamiliar with tiling WMs.
