Hi!
I intend to find someone who figured out how to fix this gap?
I called reform-handbook
before going into sway yesterday and nothing happened. I do have the latest reform-handbook
and reform-branding
packages installed.
What am I missing?
We appear to only have Pocket-reform-handbook on the git. I perceive a need to recreate the basic reform-handbook response for the terminal.
Thanks in advance.
jsae@reform ~> sudo reform-check
I: Your platform name is: MNT Reform 2 with BPI-CM4 Module
I: You are running kernel version: 6.11.7-mnt-reform-arm64
I: Your installed kernel version: 6.11.7-1+reform20241116T152555Z
I: Your installed reform-tools version: 1.60
I: not installed: firmware-misc-nonfree greetd pocket-reform-handbook tuigreet wayvnc
