Hi, in IRC you said that you are running Debian stable which I guess is from reform.d.n and that you are on charger board V2. This is important to mention with issue reports.
To rule out that this is a software issue, could you flash the latest MNT system image to an sd-card and then try to reproduce the same situation which made your Pocket behave the way it did?
Well I haven’t yet tried what @josch suggested, I have just been using Sway, which does work fine. But I managed to trigger the screen flickering via a different mechanism which I think is worth recording!
Somehow I put my pocket not-fully-turned-off in its case and my backpack and pulled it out in searing hot form, draining to 1% battery. When I realized what I did I corrected for it and let it cool down a bit before powering back on. But it was still hot when I turned it on, and the screen was flickering rapidly again!
I let it cool further with the battery disconnected and it booted it when a bit cooler, and it flickered less. Then I booted it after letting it cool off the rest of the way and it was fine!
So I think my suspicion of the flickering being related to the overheating GPU is probably right. Which doesn’t mean I shouldn’t try @josch’s recommendation of using the official Debian Unstable image and reporting back! But maybe this is useful info for something sometime, I don’t know
Updating quite some time later: I didn’t experience this the last few months when “mostly living in Sway”. I have been using swaylock, but never actually enabled it turning off my screen (wastefully!), but at FOSDEM I had a conversation with @jfred who pointed out they don’t have the rk3588 but also experience the same flickering if the screen turns itself off when idle and comes back on.
I switched back into GNOME and let the screen blank, and sure enough had this problem again!
Yeah - as mentioned my display does flicker for a while sometimes when the display turns back on after swaylock had turned it off. This is how I’m starting swaylock in my config:
Been a bit but I switched to setting the brightness to 0 when locked a while back and it’s alleviated this issue for me.
But I’m coming back here because I just ran into the flickering display again when plugging my Pocket Reform into the monitor at my desk. My Reform 2 is currently out of commission, so I’m using the Pocket as my main device for a moment. I have kanshi configured to disable all but the external monitor when it’s plugged in. But this turns off the panel in the Pocket Reform, and when I unplug it and the internal display powers back on it starts flickering.
Has there been any progress on figuring out why this happens?
