I’m truly interested in combining an external GPU with the RK3588 module of MNT Reform Next. Two of the official documents hinted about this customization:
“break out the x4 M.2 connector to something like Oculink and drive an external GPU.”
https://www.crowdsupply.com/mnt/mnt-reform-next/updates/technical-deep-dive
“you can customize this board while making use of the available space under/behind the keyboard to add external ports, like external antenna connectors, or back-facing USB.”
https://mntre.com/media/reform_md/2024-09-09-introducing-mnt-reform-next.html
I found some NVMe to OCuLink cable on Amazon or Alibaba and planned to 3D print a replacement backboard with OCuLink port and holder, but after a second look at the picture, it looks like there is a vertical PCB antenna blocking the backboard. Placing the OCuLink port on top of the MicroSD port on the left is also a choice if there is enough space.
I wonder how difficult it would be to customize the backboard with a PCB antenna. And is there anybody else who also wants a Reform Next with an external GPU?
